Problemi configurazione Amule 2.2.6 dopo l' installazione del pacchetto presente nel firmware 2.10.310
Nas Western Digital My cloud EX4
Versione Firmware: 2.10.310
PRoblemi configurazione Amule 2.2.6 dopo l’ installazione del pacchetto presente nel firmware 2.10.310
ho eseguito l’ intallazione del pacchetto come descritto nel link sottostante come utente ADMIN quindi diciamo come utente ROOT
[url]http://wdc-it.custhelp.com/app/answers/detail/a_id/11601/~/come-installare-e-utilizzare-lapp-amule-con-ununità-wd-my-cloud-ex2-o-ex4[/url]
sono entrato nell’ Amule web Control Panel dopo avere opportunamente aperto le porte:
TCP:4662
UDP:4665
TCP:4712
UDP:4672
TCP:4711
sul Router (Netgear DGN2200 V4) e sul Port Forwarding del my cloud ex4 sotto impostazioni → Rete → Port forwarding
Risultato ottenuto su Amule web Control Panel:
Connection: Connected with high ID to eMule Security No2 [xx.xxx.xx.xx:3883]
Speed: Up: 9.49KBps | Down: 5.76KBps (Limits: 20.00KBps/0 bytesps)
Serverinfo:
server version 17.15 (lugdunum)
Welcome to eMule Security! <> www.emule-security.org
Download Safe Serverlist > [url]http://www.emule-security.org/serverlist/[/url]
IP-filter > [url]FAQ - eMule Security
nodes.dat > [url]FAQ - eMule Security
Ip-To-Country database> [url]FAQ - eMule Security
eMule MODs > [url]http://www.emule-security.org/modb/[/url]
Disclaimer: This server is only indexing file-hashes, and no contains any files,
not directly involved in the exchange of files between users of p2p-network.
Administration of server is not responsible for the contents of files
shared by connected to the server users. Please do not share
copyrighted material, DRM protected media, viruses or other harmful files!
Log:
2016-01-04 00:59:53: amule.cpp(605): Starting aMuled 2.2.6 using v2.8.9
2016-01-04 00:59:53: amuled.cpp(758): ERROR: WARNING Warning! You are running aMule as root.
Doing so is not recommended for security reasons,
and you are advised to run aMule as an normal
user instead.
2016-01-04 00:59:53: ClientCreditsList.cpp(168): Creditfile loaded, 40 clients are known
2016-01-04 00:59:53: IPFilter.cpp(109): Loading IP-filters ‘ipfilter.dat’ and ‘ipfilter_static.dat’.
2016-01-04 00:59:53: IPFilter.cpp(334): Loaded 0 IP-ranges from ‘/mnt/HD/HD_a2/Nas_Prog/aMule/.aMule/ipfilter.dat’. 0 malformed lines were discarded.
2016-01-04 00:59:53: IPFilter.cpp(334): Loaded 0 IP-ranges from ‘/mnt/HD/HD_a2/Nas_Prog/aMule/.aMule/ipfilter_static.dat’. 0 malformed lines were discarded.
2016-01-04 00:59:53: ExternalConn.cpp(159): *** TCP socket (ECServer) listening on 0.0.0.0:4712
2016-01-04 00:59:53: MuleUDPSocket.cpp(81): Created Server UDP-Socket at port 4665
2016-01-04 00:59:53: MuleUDPSocket.cpp(81): Created Client UDP-Socket at port 4672
2016-01-04 00:59:53: Logger.cpp(275): Error: Lock file ‘/mnt/HD/HD_a2/Nas_Prog/aMule/.aMule/muleLock’ has incorrect permissions.
2016-01-04 00:59:53: ServerList.cpp(84): Loading server.met file: /mnt/HD/HD_a2/Nas_Prog/aMule/.aMule/server.met
2016-01-04 00:59:53: ServerList.cpp(169): 9 servers in server.met found
2016-01-04 01:00:13: DownloadQueue.cpp(171): Found 15 part files
2016-01-04 01:00:13: SharedFileList.cpp(352): Found 14 known shared files
2016-01-04 01:00:13: amule.cpp(803): Connecting
2016-01-04 01:00:13: ServerSocket.cpp(754): Connecting to eMule Security No2 (91.200.42.47 - 91.200.42.47:3883) using protocol obfuscation.
2016-01-04 01:00:13: Indexed.cpp(240): Kademlia Indexing: CSafeIOException in CIndexed::readFile: SafeIO::EOF: Attempt to read past end of file.
2016-01-04 01:00:13: RoutingZone.cpp(208): Read 0 Kad contacts
2016-01-04 01:00:15: amule.cpp(846): web server running on pid 5767
2016-01-04 01:00:15: Logger.cpp(275): Error: Cannot get the official hostname (error 0: Success)
2016-01-04 01:00:15: Logger.cpp(275): Error: Lock file ‘/mnt/HD/HD_a2/Nas_Prog/aMule/.aMule/muleLock’ has incorrect permissions.
2016-01-04 01:00:15: Connected to Kad (firewalled)
2016-01-04 01:00:15: ExternalConn.cpp(217): New external connection accepted
2016-01-04 01:00:15: ServerConnect.cpp(190): Connected to eMule Security No2 (91.200.42.47:3883)
2016-01-04 01:00:15: ThreadScheduler.cpp(308): ThreadScheduler: Completed task ‘AICH Syncronizing’, 0 tasks remaining.
2016-01-04 01:00:15: ExternalConn.cpp(251): Connecting client: aMuleweb 2.2.6
2016-01-04 01:00:15: ExternalConn.cpp(306): Access granted.
2016-01-04 01:00:15: ServerSocket.cpp(754): Connecting to eMule Security No1 (91.200.42.46 - 91.200.42.46:1176) using protocol obfuscation.
2016-01-04 01:00:15: ServerConnect.cpp(190): Connected to eMule Security No1 (91.200.42.46:1176)
2016-01-04 01:00:16: ServerConnect.cpp(263): Connection established on: eMule Security No2
2016-01-04 01:00:16: Connected to eMule Security No2 with HighID
2016-01-04 01:00:16: ServerSocket.cpp(417): New clientid is 2940740702
2016-01-04 01:00:16: ServerMessage: server version 17.15 (lugdunum)
2016-01-04 01:00:16: ServerMessage: Welcome to eMule Security! <> www.emule-security.org
2016-01-04 01:00:16: ServerMessage: Download Safe Serverlist > [url]http://www.emule-security.org/serverlist/[/url]
2016-01-04 01:00:16: ServerMessage: IP-filter > [url]FAQ - eMule Security
2016-01-04 01:00:16: ServerMessage: nodes.dat > [url]FAQ - eMule Security
2016-01-04 01:00:16: ServerMessage: Ip-To-Country database> [url]FAQ - eMule Security
2016-01-04 01:00:16: ServerMessage: eMule MODs > [url]http://www.emule-security.org/modb/[/url]
2016-01-04 01:00:16: ServerMessage: Disclaimer: This server is only indexing file-hashes, and no contains any files,
2016-01-04 01:00:16: ServerMessage: not directly involved in the exchange of files between users of p2p-network.
2016-01-04 01:00:16: ServerMessage: Administration of server is not responsible for the contents of files
2016-01-04 01:00:16: ServerMessage: shared by connected to the server users. Please do not share
2016-01-04 01:00:16: ServerMessage: copyrighted material, DRM protected media, viruses or other harmful files!
2016-01-04 01:02:01: Connected to Kad (ok)
2016-01-04 01:15:42: SharedFileList.cpp(352): Found 14 known shared files
2016-01-04 01:15:42: ThreadScheduler.cpp(308): ThreadScheduler: Completed task ‘AICH Syncronizing’, 0 tasks remaining.
ho abilitato l’ SSh sul Nas wd My cloud ex 4 e aperto porta 22 sia nel Port Forwarding del nas sia sul mio router porta 22.
mi sono collegato tramite SSH con Putty da windows e sono entrato nella cartella
/home/root/.aMule
ho editato il file amule.conf come segue:
[eMule]
AppVersion=2.2.6
Nick=pincopallino
QueueSizePref=15 ### limita il carico del server in upload
VerboseDebug=0
MaxUpload=15 ###limita il carico del server in download
MaxDownload=15 ###quota banda che ciascun peer succhia
SlotAllocation=5
Port=4662
UDPPort=4672
UDPDisable=0
Address=
Autoconnect=1 ### limitare per ridurre carico al NAT del router
MaxSourcesPerFile=100 ### limitare per ridurre carico al NAT del router
MaxConnections=200
MaxConnectionsPerFiveSeconds=20
RemoveDeadServer=1
DeadServerRetry=3
ServerKeepAliveTimeout=0
Reconnect=1
Scoresystem=1
Serverlist=1 ### Serverlist=0 auto update the server list from the supplied url
AddServerListFromServer=1 ### AddServerListFromServer=0
AddServerListFromClient=0
SafeServerConnect=0
AutoConnectStaticOnly=0
UPnPEnabled=0
UPnPTCPPort=50000
SmartIdCheck=1
ConnectToKad=1
ConnectToED2K=1
TempDir=/shares/aMule/Temp
IncomingDir=/shares/aMule/Incoming
ICH=1
AICHTrust=0
CheckDiskspace=1
MinFreeDiskSpace=1
AddNewFilesPaused=0
PreviewPrio=0
ManualHighPrio=0
FullChunkTransfers=1
StartNextFile=0
StartNextFileSameCat=0
FileBufferSizePref=16
DAPPref=1
UAPPref=1
AllocateFullFile=0
OSDirectory=/home/root/.aMule/
OnlineSignature=0
OnlineSignatureUpdate=5
EnableTrayIcon=0
MinToTray=0
ConfirmExit=1
StartupMinimized=0
3DDepth=10
ToolTipDelay=1
ShowOverhead=0
ShowInfoOnCatTabs=1
ShowRatesOnTitle=0
VerticalToolbar=0
ShowPartFileNumber=0
VideoPlayer=
VideoPreviewBackupped=1
StatGraphsInterval=3
statsInterval=30
DownloadCapacity=0 ### limita banda occupata in download
UploadCapacity=20 ### limita banda occupata in upload
StatsAverageMinutes=5
VariousStatisticsMaxValue=100
SeeShare=2
FilterLanIPs=1
ParanoidFiltering=1
IPFilterAutoLoad=1
IPFilterURL=
FilterLevel=127
IPFilterSystem=0
FilterMessages=1
FilterAllMessages=0
MessagesFromFriendsOnly=0
MessageFromValidSourcesOnly=1
FilterWordMessages=0
MessageFilter=
FilterComments=0
CommentFilter=
ShareHiddenFiles=0
AutoSortDownloads=0
NewVersionCheck=1
Language=
SplitterbarPosition=75
YourHostname=
DateTimeFormat=%A, %x, %X
AllcatType=0
ShowAllNotCats=0
SmartIdState=0
DropSlowSources=0
KadNodesUrl=http://www.emule-mods.it/download/nodes.dat ### (originale) [url]http://emule-inside.net/nodes.dat[/url]
Ed2kServersUrl=http://gruk.org/server.met ### (originale) [url]http://gruk.org/server.met.gz[/url]
[Browser]
DefaultBrowser=0
OpenPageInTab=1
CustomBrowserString=
[Proxy]
ProxyEnableProxy=0
ProxyType=0
ProxyName=
ProxyPort=1080
ProxyEnablePassword=0
ProxyUser=
ProxyPassword=
[ExternalConnect]
UseSrcSeeds=0
AcceptExternalConnections=1 ### Abilita l’uso delle interfacce web e GUI
ECAddress=
ECPort=4712
ECPassword=ef7628c92bff39c0b3532d36a617cf09
UPnPECEnabled=0
ShowProgressBar=1
ShowPercent=1
UseSecIdent=1
IpFilterClients=1
IpFilterServers=1
[WebServer]
Enabled=1
PasswordLow=
Port=4711
WebUPnPTCPPort=50001
UPnPWebServerEnabled=0
UseGzip=1
UseLowRightsUser=0
PageRefreshTime=120
Template=
[Razor_Preferences]
FastED2KLinksHandler=1
[SkinGUIOptions]
UseSkinFiles=0
Skin=
[Statistics]
MaxClientVersions=0
TotalDownloadedBytes=0
TotalUploadedBytes=0
[Obfuscation]
IsClientCryptLayerSupported=1
IsCryptLayerRequested=1
IsClientCryptLayerRequired=0
CryptoPaddingLenght=254
CryptoKadUDPKey=1230772601
[UserEvents]
[UserEvents/DownloadCompleted]
CoreEnabled=0
CoreCommand=
GUIEnabled=1
GUICommand=
[UserEvents/NewChatSession]
CoreEnabled=0
CoreCommand=
GUIEnabled=0
GUICommand=
[UserEvents/OutOfDiskSpace]
CoreEnabled=0
CoreCommand=
GUIEnabled=0
GUICommand=
[UserEvents/ErrorOnCompletion]
CoreEnabled=0
CoreCommand=
GUIEnabled=0
GUICommand=
[Debug]
Cat_General=0
Cat_Hasher=0
Cat_ED2k\ Client=0
Cat_Local\ Client\ Protocol=0
Cat_Remote\ Client\ Protocol=0
Cat_Packet\ Parsing\ Errors=0
Cat_CFile=0
Cat_FileIO=0
Cat_ZLib=0
Cat_AICH-Hasher=0
Cat_AICH-Transfer=0
Cat_AICH-Recovery=0
Cat_ListenSocket=0
Cat_Credits=0
Cat_ClientUDPSocket=0
Cat_DownloadQueue=0
Cat_IPFilter=0
Cat_KnownFileList=0
Cat_PartFiles=0
Cat_SHAHashSet=0
Cat_Servers=0
Cat_Proxy=0
Cat_Searching=0
Cat_ServerUDP=0
Cat_Client\ Kademlia\ UDP=0
Cat_Kademlia\ Search=0
Cat_Kademlia\ Routing=0
Cat_Kademlia\ Indexing=0
Cat_Kademlia\ Main\ Thread=0
Cat_Kademlia\ Preferences=0
Cat_PartFileConvert=0
Cat_MuleUDPSocket=0
Cat_ThreadScheduler=0
Cat_Universal\ Plug\ and\ Play=0
Cat_Kademlia\ UDP\ Firewall\ Tester=0
Cat_Kademlia\ Packet\ Tracking=0
Cat_Kademlia\ Entry\ Tracking=0
inoltre ho inserito nel file shareddir.dat gli indirizzi delle cartelle che voglio condividere…
  1. Se riavvio il Nas Wd My Cloud ex4 tutte le mie impostazioni vengono cancellate tuut le mie impostazioni del file amule.conf e shareddir.dat cancellate!!!
  2. Inoltre non riesco ad accedere ad aMule se non come Root, e se faccio una ricerca di un file qualsiasi in rete kad o e2k o globale trova al massimo file di 4 gb e non oltre…
    cosa molto strana…per aggirare quest’ ultimo problema devo cercare un file con amule installato su un pc metterlo in download e copiare il suo file 001.part dalla cartella temp di amule su pc a quella temp di amule sul nas, Riavviare il nas e mi la ritrovo il file in download su amule del nas anche se è di 15 gb…
  3. Non riesco ad accedere con Amulegui 2.2.6 al demone di amule sul nas… (Errore:Accesso negato a causa di un autenticazione non riuscita!!!)
vi chiedo aiuto…ho appena sostituito il mio vecchio server-xubutu con il nas wd my cloud ex4 perchè avevo letto che al suo interno potevano girare Amule e
Transimission…se no compravo un altro server invece che un nas. Trasmission una volta configurato va alla grande…amule diciamo che è stato inserito solo per attirare gli acquirenti…perchè messo come è messo liscio lasciandolo stare come da installazione senza mod è inutilizzabile…
Grazie per la pazienza attendo risposte…
Utilizzo amchio Amule sul mio NAS ed ho notato che accade la stessa cosa, gli altri utenti non possono accedere ma solo l’amministratore
