I bought My Passport 5TB External drive from WD a year ago and I failed to get it to run for Backup. After many attempt I realised I needed first to Install Discovery. Did that, now trying to run ‘My Cloud’ during registration Im asked to giver 9 digit Device Code, but it’s not visible anywhere on my drive. so where to next? I’ve sought Support advice and also requested return number to send it back, but nothing forthcoming. Incident reported 16/08/20 200816-001737 refers
Now currently ‘losing the will to live’
So last desperate measure is to seek Community Support. How difficult should it be ?
I am sorry the MacOS experience is not working out for you as far as the WD product is concern. If you bought the HDD from Amazon, you should have noticed that you have to reformat the HDD before you can use it on the Mac. The WD installer doesn’t recognize the disk because it is in NTFS format which the Mac can only read but not write. The attempt to run ‘My Cloud’ may be just an installer or user error. So you have to go to MacOS disk util to reformat the HDD. This forum has nothing to do with your My Passport and neither has it anything to do with the ‘My Cloud’ (without the ‘Home’).
