Power Supply Error Message
I just received the following error message on my EX2. Should I be concerned? When I check the device everything looks great and it is reporting as healthy when I logged in to check.
Following events are generated on your WDMyCloudEX2 .
Event title:Power Supply Failure
Event description:Power supply failed. Check power supply.
Severity:warning
Event code:1022
Event time:10-30-2015 04:53:22 PM
Firmware version: 2.10.310
Event title:Media Scan Stopped
Event description:The device stopped scanning your media. As a result, some thumbnails will not display when you access them remotely. To resume scanning, please restart your WD My Cloud system.
Severity:Info
Event code:2300
Event time:10-23-2015 03:13:31 AM
Hi there,
When you reboot the device, do you get the same message again from the unit?
