Power and Management MyBook 3TB USB3
How do I install WD utility to auto power off MyBook drives.
I do not want to install the backup SmartWare program, I only want to install the utility
thanks
The My Book should go automatically into sleep mode when not in use. Check if one of the programs installed on your PC is using the My Book.
thank you
Some software  that might be causing the problem could be auto backup or sync software. Also AV might be scanning in background.
Joe
It started working now and I didn’t even change or do anything!
Thank you… I appreciate your time
