OS5 and firmware 5.05.111
I was struggling with the OS5 upgrade. I have upgraded my fiwrmware on my Mycloud Mirror GEN2 to version 5.05.111 and now the indexation is much faster. I did 30% of intxation in 2h hours.
The NAS is more responsiveness and I was able to reconfigure my cloud users to use smartphone and remote accesses:
It seems that this new firmware solve my issues
Did anybody had the same experience?
Just found the update:
https://os5releasenotes.mycloud.com/#/
Where did you see the progress?
OK, it is new in this version.
Good news, because my device is indexing since 2 weeks now and I don’t know about the progress.
Hello
after 5.05.111 I see cloud access as “failed”
Why is that ?
Try to connet your admin account to the cloud
Hi all - how do you manually update the firmware to [5.05.111]. Is there any guide how to do it? thanks in advance.
Download firmware for your device
https://support-en.wd.com/app/products/product-detail/p/137#WD_downloads
Go to the dashboard → settings → firmware update → manual update and select the file.
thanks!!!
