just got wd elements and it should be performated for the MacBook and I should be able to drag and drop files. trying to move photos but when you hover over the elements drive it will not accept the files. do I need to download software as well? does not say I need to but can’t use the drive
You could refer to the following link: Instructions to Format a Drive for Use with Windows or macOS
