MyCloud System Reset
Hi, with regards to System only reset - I understand that the data is NOT lost, but the users are reset to admin only (one user). My question is - What happens to the data of the other users on the drive?
Thank You
Are you talking about this, see image below? Click on, tap or activate image to enlarge it.
Have you looked at the User Manual.
Hi, Thanks for your reply. Yes that is what I am referring to - System Factory Restore - System Only. This will keep all data, but apparently keeps only one user? So what happens to other user data? Many Thanks
