My old MyBook just failed two days ago (my fault) and I need to replace it ASAP.
Facts:
I need a product to 1) back-up my iMac and MacBook using Time Machine (over Wifi) and 2) to store some files (mainly Video) to be accessed from my devices. This time I want to have a Raid 1 set-up to cope with any failure as the documents stored (2) have no back-up.
One solution could be MyCloud Home Duo 8Tb but I am thinking about one MyCloud Home 4Tb and one more product 4Tb to mirror the first one. This second option would be less expensive and, to me more important, I would have two completely separated devices which in my opinion should mitigate the risk of failure.
Questions:
- Any advice/comment about the second option?
- Which product would you suggest to mirror MyCloud Home 4Tb? As far as I understand i cannot just plug the second product via USB. One more MyCloud Home 4Tb?
- in connection with question 2) is MyCloud Home 4Tb the way to go or as primary product I should go for a different one? Please note that Wi-fi time machine back-up from multiple computer is a must
Thank you!!!
