My Passport Wireless pro has a problem
until few days ago, I could easily go connect to my passport 5ghz or 2.4ghz network outside(not home) without a problem but now I can not connect to those two networks outside at all. At home it connects very easily. when it doesn’t connect the message shows “internet may not be available. Connect to another network”. Does anyone have similar problems like this and solved it?
Hi there,
Is this when you try to connect a device to the drive or when you try to connect the drive to a router?
what device are you trying to connect to the MPW Pro? sounds like that device is verifying if the Wi-Fi network you are connecting to has valid internet connection to determine if it can be connected. Have you tried other devices?
