Hi, I stupidly formatted my password wireless pro from Windows explorer, and now can’t use it. Have tried installing the update via SD card but that doesn’t work, is there a firmware file anywhere,i can’t find one?
Hope someone out there can help!
Reformatting the My “Passport” Wireless Pro will not render it “useless”.
The User Manual even States it’s OK to do so if you want to … Page 52
Heck, i have the older the My Passport Wireless and have reformatted it a few times and it still works perfectly fine. All Wireless Functions/Setup etc work perfectly fine after formatting the hard drive.
You’re right, I tried it after reading your reply, and it’s fine, I think I was going round in circles yesterday! Many thanks.
