My passport wireless 2tb,
Battery bloated
How to replace or fix it???
No replace, WD sells device with no repair possibility. Batteries replacement should be a must in this kind of devices…
I have the same problem with my battery. Did you manage to solve this? Did you get a battery to replace this one? Thank you if you can help me !!!
