My Book Live Duo - Green LED not stopping blinking
My green LED is never stopping blinking.
I have tried to disconnect the MBLD from the network, to untick remote access … but it never stop blinking.
Any idea how to fix this?
Thanx
Hello, what version of the firmware you have installed on the drive? Have you turned off the media serving feature on the drive?
I have version 02.43.10-048.
I have also turned off the media feature and the online access.
I noticed that even when the ethernet cable is disconnected (ie the NAS is not connected to internet), the LED is still blinking.
Any idea?
Thanx
You might want to reset the drive by pressing the reset button in the back and see if that helps with the issue at hand, if it doesn’t I would recommend you to contact support
I’ll give a try with the reset button on the back.
Many thanks for your help
Last news: problem solved.
Today, before doing a reset, I’ve done a full backup of my MBLD. I didn’t want to lose any data following the reset (just in case).
Once the backup finished, the LED was green and not blinking anymore. Then, 20 minutes later, the LED’s color changed to blue (standby).
Everything is back to normal but I don’t understand what happened.
