Monitoring HDD temps & fan speed in DL2100
Can you monitor the temps of the HDD’s with software?
Does the fan speed vary according to some inside temp or HDD activity?
thanks
I do not really understand if you want to monitor the HDD’s with other software or from the NAS.
If you want to see the HDD temp, you have Home> Device> Diagnostics > click on the arrow and you will see the temp and FAN speed. Also YES, the fan speed is changing acording to HDD temp
