Looking for second AC Adapter for WD My Cloud EX4100, Asian Power Devices, Inc., P/N DA-90F19
I have been unable to locate a second AC adapter for My Cloud EX4100 in WD Store. I am a bit amazed that WD doesn’t offer power supplies to support their units.
You can purchase aftermarket power supplies on Amazon or eBay, but this may void your warranty.
I found a few offerings, but unsure which would be correct as each has a different adapter plug size:
Adapter Plug Size: 5.5 x 1.7mm
Adapter Plug Size: 5.5 x 2.5mm
Here is another one which looks to be identical in description, but not sure what the adapter plug size is:
http://www.viewsonic.com/parts/a-00009635.html
Hope this helps!
Have you try contacting WD Support about this? I believe that you can buy the power adapter through the support team.
https://support.wdc.com/support/case.aspx?lang=en
I understand the original poster. Why do he has to contact support to purchase a regular spare part?
This should be widely available through amazon or such. Or at least on the WD website. I’m amazed there is no such offer…
