Can't found any replacement power adaptor 90w
WD write on their website to check on WD store for 90w replacement power adaptor but I think they dont have it anymore. They are really hard to find on internet. Do you know if they still sell them?
Thank you a lot
I’d recommend sending an E-mail to WD Support about this. The inventory in the WD Online Store is different from the inventory used by the WD Support team, and they may be able to provide you with the power adapter for free if your unit is still under warranty.
