This drive is powered from the USB port I suppose? If so the inrush current is likely more that the USB port on the WDMyCloud and handle. It works fine with a drive powered by its own power supply. Something like a WD My Book 3TB Desktop USB 3.0 External Hard Drive Storage for instance.
Another option is to connect through a powered USB2 hub, I have this arrangement and can now attach 4 devices i.e
USB powered HDD, SD card reader, USB memory stick. etc the WDMyCloud recognises all of them as Shares and they can be accessed individually through Windows Explorer
Wd My Cloud disconnects/crashes after a “powered USB hub” is connected with external hard disks
Hello guys,
It seems the problem is much more serious.
I have Wd My Clud 4T fully working attached to the network.
I configured a powered USB 2.0 hub with 7 slot ports that I connected to the USB port of my white WD My Cloud; I attached 3 Hard Disks to this hub.
When I connect the hub My Cloud starts analysing it, it recognized 3 Hard Disks on 4 and after some minutes it does not reply anymore to web interface (disconnected? crashed?).
Well it really depends upon the USB hub that you are using. The better ones are powered and completely isolate the devices from each other’s power. The cheaper ones do not do that. I found this out when working with the Raspberry Pi, not all powered hubs are created equal in this regard. I believe that if you look into this issue over on the Raspberry Pi you will find a lot of useful information on this topic.
