Hi— I have been trying for several hours to find the driver for my driver. I have a WD320GB Scorpio Black which I have made as an external drive. For the love of God, why I can’t get the driver is beyond me. The serial # is WX10AB918124, WD3200BEKT-00F3T0. I am quite frustrated that they replaced the drive with not a bit of paperwork in how to use the drive. My computer does not recogzine the drive, that is why I am trying to locate the driver.Anyone , advice??? Thank you so very much.
Since there’s been no replies, maybe you should try contacting WD’s Technical Support about this. You can do so either by phone or email. However, you should need drivers for the internal drive. Your operating system should install them automatically.
