Hi
I simply can´t get the FTP part to work with my nas. (everything else works fine)…
I have set “FTP Enable” in the UI.
I have made a port forwarding, not quite sure if this is right, but this is how it looks:
In the UI of the Nas:
Configure settings for remote access to your My Book Live.
Port forwarding connection established.
Connection Options:
Manual Windows XP compatibility Manual
| Automatic |
| Application Description | External Port | Internal Port | Protocol | IP Address (My Book Live) |
| WD 2go Port 1:* | 8080 | 80 | 192.168.2.187 | |
| WD 2go Port 2:* | 8443 | 443 | 192.168.2.187 |
In my Router:
Port Forwarding Enabled
rule name
MBL80 MBL443 |
LAN IP
192.168.2.187 192.168.2.187 |
PROTOCOL
TCP TCP |
LAN PORT
80 443 |
WAN PORT
8080 8443 |
When I try to use FTP (with cuteftp), I use:
Host: wd2go.com
User: admin (default in UI)
password: the one I created in the UI of the Nas.
I am not even sure what I should put in the Port field when I try to connect.
Sometimes it says:
Socket connected, waiting for welcome message… but then nothing more happens…
Really hope I can get some help with this, going Crazy (on day 3 now)…
Best Regards
Henrik
