[GUIDE] Install Transmission 2.77
UPDATED 4/30/2013
I DON’T USE TORRENTS, SO ANY FEEDBACK IS APPRECIATED
I DID DOWNLOAD UBUNTU 12.10 FROM A TORRENT ON THEIR PAGE AND MAXED OUT MY 30Mb CONNECTION
UPDATE 1: ADDED AN INIT.D SCRIPT SO THE APP AUTO-STARTS ON A MBL REBOOT
UPDATE 2: ADDED THE OPTION TO STORE TORRENTS ON THE DATAVOLUME
Mad props to Timmy1024 for the modified startup script which now auto updates the blocklist!
Lists will update everytime you restart your device (or manually run the init script with /etc/init.d/transmission-daemon)
This SHOULD work on the latest MBLDUO firmware as well
Connect to the MBL with PuTTY or Terminal and install optware
wget http://mybookworld.wikidot.com/local--files/optware/setup-mybooklive.sh
sh setup-mybooklive.sh
Issue the following commands to ensure that we can use the command “ipkg” from any directory
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /root/.bashrc
echo "export PATH=$PATH:/opt/bin:/opt/sbin" >> /etc/profile
Close PuTTY or Terminal (Very Important)
Open PuTTY or Terminal and connect to the MBL again
ipkg update
ipkg install transmission libevent
Start Transmission
/opt/bin/transmission-daemon
Stop Transmission
killall transmission-daemon
Delete the json settings file and replace it with the text in the REPLACEMENT TEXT window
rm /root/.config/transmission-daemon/settings.jsonnano /root/.config/transmission-daemon/settings.json
REPLACEMENT TEXT (Right mouse click in the PuTTY window to paste)
{    "alt-speed-down": 50,     "alt-speed-enabled": false,     "alt-speed-time-begin": 540,     "alt-speed-time-day": 127,     "alt-speed-time-enabled": false,     "alt-speed-time-end": 1020,     "alt-speed-up": 50,     "bind-address-ipv4": "0.0.0.0",     "bind-address-ipv6": "::",     "blocklist-enabled": true,     "blocklist-url": "http://www.bluetack.co.uk/config/level1.gz",     "cache-size-mb": 4,     "dht-enabled": true,     "download-dir": "/DataVolume/shares/Public/TR-Downloads",     "download-queue-enabled": true,     "download-queue-size": 5,     "encryption": 1,     "idle-seeding-limit": 30,     "idle-seeding-limit-enabled": false,     "incomplete-dir": "/DataVolume/shares/Public/TR-INCOMPLETE",     "incomplete-dir-enabled": true,     "lpd-enabled": false,     "message-level": 2,     "peer-congestion-algorithm": "",     "peer-limit-global": 240,     "peer-limit-per-torrent": 60,     "peer-port": 51413,     "peer-port-random-high": 65535,     "peer-port-random-low": 49152,     "peer-port-random-on-start": false,     "peer-socket-tos": "default",     "pex-enabled": true,     "port-forwarding-enabled": false,     "preallocation": 1,     "prefetch-enabled": 1,     "queue-stalled-enabled": true,     "queue-stalled-minutes": 30,     "ratio-limit": 2,     "ratio-limit-enabled": false,     "rename-partial-files": true,     "rpc-authentication-required": false,     "rpc-bind-address": "0.0.0.0",     "rpc-enabled": true,     "rpc-password": "{5d73272dade2dccb326e823e555a8bccd6c235f2SkqI2LBJ",     "rpc-port": 9091,     "rpc-url": "/transmission/",     "rpc-username": "",     "rpc-whitelist": "127.0.0.1",     "rpc-whitelist-enabled": false,     "scrape-paused-torrents-enabled": true,     "script-torrent-done-enabled": false,     "script-torrent-done-filename": "",     "seed-queue-enabled": false,     "seed-queue-size": 10,     "speed-limit-down": 100,     "speed-limit-down-enabled": false,     "speed-limit-up": 100,     "speed-limit-up-enabled": false,     "start-added-torrents": true,     "trash-original-torrent-files": false,     "umask": 0,     "upload-slots-per-torrent": 14,     "utp-enabled": true}
Hit control and o
Hit enter
Hit control and x
This will save your edited file
Change the file permissions
chmod 600 /root/.config/transmission-daemon/settings.json
Now we are gonna create a startup script
nano /etc/init.d/transmission-daemon
Copy the following text to the PuTTY window (Right mouse click in the PuTTY window to paste)
#! /bin/sh### BEGIN INIT INFO# Provides:          transmission-daemon# Required-Start:    $remote_fs# Required-Stop:     $remote_fs# Default-Start:     2 3 4 5# Default-Stop:      0 1 6# Short-Description: Start or stop the transmission-daemon# Description:       This file should be used to construct scripts to be#                    placed in /etc/init.d.### END INIT INFOTRANSMISSION_BLOCKLISTS_DIRECTORY=/root/.config/transmission-daemon/blocklists# Bluetack: badpeers# http://www.iblocklist.com/list.php?list=bt_templistwget -P $TRANSMISSION_BLOCKLISTS_DIRECTORY/ "http://list.iblocklist.com/?list=bt_templist&fileformat=p2p&archiveformat=gz"rm -f $TRANSMISSION_BLOCKLISTS_DIRECTORY/bt_templistgunzip $TRANSMISSION_BLOCKLISTS_DIRECTORY/bt_templist.gz# Bluetack: level1# http://www.iblocklist.com/list.php?list=bt_level1wget -P $TRANSMISSION_BLOCKLISTS_DIRECTORY/ "http://list.iblocklist.com/?list=bt_level1&fileformat=p2p&archiveformat=gz"rm -f $TRANSMISSION_BLOCKLISTS_DIRECTORY/bt_level1gunzip $TRANSMISSION_BLOCKLISTS_DIRECTORY/bt_level1.gz# The Blocklist Group: Primary Threats# http://www.iblocklist.com/list.php?list=ijfqtofzixtwayqovmxn&fileformat=p2p&archiveformat=gzwget -P $TRANSMISSION_BLOCKLISTS_DIRECTORY/ "http://list.iblocklist.com/?list=ijfqtofzixtwayqovmxn&fileformat=p2p&archiveformat=gz"rm -f $TRANSMISSION_BLOCKLISTS_DIRECTORY/ijfqtofzixtwayqovmxngunzip $TRANSMISSION_BLOCKLISTS_DIRECTORY/ijfqtofzixtwayqovmxn.gz# Do NOT "set -e"# PATH should only include /usr/* if it runs after the mountnfs.sh scriptPATH=/opt/sbin:/opt/bin:/sbin:/usr/sbin:/bin:/usr/binDESC="Transmission - daemon"NAME=transmission-daemonDAEMON=/opt/bin/$NAMEDAEMON_ARGS="--options args"#PIDFILE=/var/run/$NAME.pidSCRIPTNAME=/etc/init.d/$NAMEUSER=rootSTOP_TIMEOUT=3# Exit if the package is not installed[-x "$DAEMON"] || exit 0[-e /etc/default/$NAME] && . /etc/default/$NAME# Read configuration variable file if it is present[-r /etc/default/$NAME] && . /etc/default/$NAME# Load the VERBOSE setting and other rcS variables. /lib/init/vars.sh# Define LSB log_* functions.# Depend on lsb-base (>= 3.0-6) to ensure that this file is present.. /lib/lsb/init-functions## Function that starts the daemon/service#do_start(){    # Return    #   0 if daemon has been started    #   1 if daemon was already running    #   2 if daemon could not be started    if [$ENABLE_DAEMON ! = 1] ; then        log_progress_msg "(disabled, see /etc/default/${NAME})"    else            start-stop-daemon --start \        --chuid $USER \        --exec $DAEMON -- $OPTIONS    fi    # Add code here, if necessary, that waits for the process to be ready    # to handle requests from services started subsequently which depend    # on this one.  As a last resort, sleep for some time.}## Function that stops the daemon/service#do_stop(){    # Return    #   0 if daemon has been stopped    #   1 if daemon was already stopped    #   2 if daemon could not be stopped    #   other if a failure occurred    start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE --name $NAME    RETVAL="$?"    ["$RETVAL" = 2] && return 2    # Wait for children to finish too if this is a daemon that forks    # and if the daemon is only ever run from this initscript.    # If the above conditions are not satisfied then add some other code    # that waits for the process to drop all resources that could be    # needed by services started subsequently.  A last resort is to    # sleep for some time.    start-stop-daemon --stop --quiet --oknodo --retry=0/30/KILL/5 --exec $DAEMON    ["$?" = 2] && return 2    # Many daemons don't delete their pidfiles when they exit.    rm -f $PIDFILE    return "$RETVAL"}## Function that sends a SIGHUP to the daemon/service#do_reload() {    #    # If the daemon can reload its configuration without    # restarting (for example, when it is sent a SIGHUP),    # then implement that here.    #    start-stop-daemon --stop --signal 1 --quiet --pidfile $PIDFILE --name $NAME    return 0}case "$1" in  start)    ["$VERBOSE" != no] && log_daemon_msg "Starting $DESC" "$NAME"    do_start    case "$?" in        0|1) ["$VERBOSE" != no] && log_end_msg 0 ;;        2) ["$VERBOSE" != no] && log_end_msg 1 ;;    esac    ;;  stop)    ["$VERBOSE" != no] && log_daemon_msg "Stopping $DESC" "$NAME"    do_stop    case "$?" in        0|1) ["$VERBOSE" != no] && log_end_msg 0 ;;        2) ["$VERBOSE" != no] && log_end_msg 1 ;;    esac    ;;  #reload|force-reload)    #    # If do_reload() is not implemented then leave this commented out    # and leave 'force-reload' as an alias for 'restart'.    #    #log_daemon_msg "Reloading $DESC" "$NAME"    #do_reload    #log_end_msg $?    #;;  restart|force-reload)    #    # If the "reload" option is implemented then remove the    # 'force-reload' alias    #    log_daemon_msg "Restarting $DESC" "$NAME"    do_stop    case "$?" in      0|1)        do_start        case "$?" in            0) log_end_msg 0 ;;            1) log_end_msg 1 ;; # Old process is still running            *) log_end_msg 1 ;; # Failed to start        esac        ;;      *)          # Failed to stop        log_end_msg 1        ;;    esac    ;;  *)    #echo "Usage: $SCRIPTNAME {start|stop|restart|reload|force-reload}" >&2    echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2    exit 3    ;;esac:
Hit control and o
Hit enter
Hit control and x
Set the script permissions and add it to all the rc folders
chmod 755 /etc/init.d/transmission-daemon
update-rc.d transmission-daemon defaults
For those wishing to have access to the actual Torrent files easily from the DataVolume
Create a folder called torrents in your Public folder
SSH in and move any Torrents you currently have in /root/.config/transmission-daemon/torrents to your computer
SSH in and issue
rmdir /root/.config/transmission-daemon/torrents
ln -s /DataVolume/shares/Public/torrents /root/.config/transmission-daemon/torrents
Your torrents will now be stored in /Public/torrents
Start Transmission again
/etc/init.d/transmission-daemon start
Login to Transmission using a web browser using your mybooklive network name or ip:9091
Click the wrench icon and go to the peers tab and make sure you click UPDATE to setup your Blocklist
Make any other changes you need from the GUI as well
 DONE!
Thanks nfodiz.
Any chance you have a script to automatically extract RAR’ed archives into another folder upon download completion?
Eg. Torrent finishes downloading into the default destination folder. MBL script automatically senses this and extracts .avi file into a different folder for viewing on other DNLA devices.
Bonus points for leaving the original torrent in its original location to allow uploading/seeding to continue.
Cheers,
Ocean.
UPDATED 4/29/2013
TorrentExpander Auto Unrar and Unzip script Guide
To see all that TorrentExpander is capable of, see the following link
http://code.google.com/p/torrentexpander/
Features:
  • Automatically extract compressed archive
  • Rename Movie & Series as you like
  • Automatically copy or move your downloads in ordered directory
  • Build .nfo for each movie file (useful with Jukebox or Movie Catalog software)
  • Download Poster from imdb
  • Download Fanart from TheMovieDB
  • Put Movies, Series and Music in different folders
  • Automatically update itself
  • Many More
First stop Transmission Daemon
You will need to download these dependencies for the script
ipkg install unrar
 Edit settings.json
Replace these lines
With these lines
"script-torrent-done-enabled": true,
    "script-torrent-done-filename": "/var/lib/scripts/torrentexpander.sh",
Hit control and o
Hit enter
Hit control and x
Create the scripts directory, download the script, and make it executable
mkdir /var/lib/scripts
cd /var/lib/scripts
wget http://torrentexpander.googlecode.com/svn/trunk/torrentexpander.sh
chmod 755 /var/lib/scripts/torrentexpander.sh
Now lets run the setup script
The only change you NEED to make is to:
destination_folder=no
Change it to
destination_folder=/DataVolume/shares/ whatever share and folder you want the files extracted to
Make sure the share and folder already exist on the NAS
Extracted ZIP and RAR archives will be extracted here in a folder named after the archive
Non-archive files will also be placed in this folder
Hit control and o
Hit enter
Hit control and x
DONE!
Guide updated with a proper init.d startup script so transmission will now automatically start if you reboot the drive
Thankyou kindly. I’ll give it a go and report back with results. :smiley:
[Edit] The “Install Transmission” Guide works perfectly. My “FeaturePack Manager” (with associated software) was wiped when I upgraded to WD’s latest firmware today (v 02.42.02-012). I followed your instructions above and can confirm each step works correctly. Thank you very much.
As a suggestion (and to prevent further enquiries from linux noobs like me), could you please add the following instructions after the sections where nano text is to be replaced within the files?
Eg.
Press Ctrl-o, then press Enter
Press Ctrl-x to save the file.
I’ll report back on the second section of the guide (the auto-extraction section) after I’ve tried it. Cheers!
Wow, I don’t know how I missed that as I always have those steps listed in my guides. Will make that change today when I get to my desktop. Thank you for pointing it out :slight_smile:
EDIT: Guide updated
Thanks nfo! You’re THAT guide in every forum community that is truly dedicated to helping the community! :smiley:
I’ll try this as soon as I have time (and finish fiddling with the apache settings ;))
Can’t thank you enough, so I kudos’ed (?) every post :slight_smile:
See ya
LOL; *guy (instead of guide!)
[Edit] - This post is outdated as the Auto-Extract Script Guide has been updated.
Hi there,
I found I needed to create a “scripts” directory to allow the posttorrent.sh script to save:
cd /root
I also found that if I wanted to keep the original .rar files for seeding, I had to edit the “posttorrent.sh” file and get rid of the part that said:
transmission-remote -n $TR_USERNAME:$TR_PASSWORD -t $TR_TORRENT_HASH --remove-and-delete
 …and replace with:
I downloaded a small 80MB video that was in .rar form to test if the script works - but I can’t find it anywhere on my MBL!
Might start over again!!
LOL, keep me posted and we can collaborate and add it to the guide :slight_smile: Take good notes
I confirm that this worked great on the My Book Live Duo.
I had to change the download directory, because even though it was DataVolume/shares/Public/, the downloaded files didn’t appear there (I don’t know where they went)
I’ll try the automatic unrar as soon as it’s fixed, thanks for that too.
By the way, I’ll restore the disks images from the mybookwiki site… so wish me luck, hopefully the drives won’t brick even more! :open_mouth:
Hello nfodiz!
Another brilliant guide from you! Just installed Transmission on My Book Live with the latest firmware version which just came out and it seems to work perfectly fine. The only thing that confused me that I can’t see the download folder TR-Downloads in /DataVolume/shares/Public If I understand correctly incomplete torrent files are  temporarily stored in /root/DataVolume/shares/Public/TR-Downloads When the file has finished downloading it is finally moved to /DataVolume/shares/Public/TR-Downloads
Thanks for great guide!
If I remember correctly, the folder wasn’t created until I downloaded Ubuntu 12.10 torrent to test it. I will look into this more later. It may be I need to change paths. I will be away until aroud noon EST today
Yep, my download is going directly to Public/TR-Downloads as a .part file
If you get an incomplete download I’m guessing it would create a TR-INCOMPLETE folder and move it there?
EDIT: You need to stop transmission and edit this line with nano
“incomplete-dir-enabled”: false,
to
“incomplete-dir-enabled”: true,
Restart Transmission
It should then create a TR-INCOMPLETE folder in the Public folder for downloads and move the download to TR-Downloads when complete
Should I edit the guide to reflect this change?
Thanks for the finding nfo. Sure, you could edit it if you want, for posterity and other users finding it :slight_smile:
By the way, do you know where (and if) .torrent files are saved? For example, in uTorrent there is a special folder dedicated to keeping the .torrent files. Does Transmission do the same?
The torrent files are saved to /root/.config/transmission-daemon/torrents
Not sure if we can change that or not. I would prefer to have them somewhere on the DataVolume
Wouldn’t a symlink work? Replace that dir with a symlink to another pointing at the shares/xxx?
yep, was just gonna post that lol
SSH in and issue
My question now is how do I save the .torrent file? Once I remove a file from the Transmission screen it removes the .torrent file as well.
I know it needs to stay there as long as I am seeding, but what about when I’m done seeding? Is there any reason to keep the .torrent file? If not, the whole symlink thing really isn’t necessary as the .torrent files wouldn’t build up and take up alot of space, correct?
Please excuse my noobiness on Torrents :slight_smile:
