Fried a WD red by sending 19v to it. Help with TVS/Fuse repair
Same story as everyone else who has done this, sent 19v through an external drive bay and fried a WD RED WD40EFRX, using a Klein Multimeter CL800 and some forum threads i have identified these diodes/fuses to check resistance on. The values are below.
R43: 0.3 ohm / 0.3 ohm
R60: 0.3 ohm / 0.3 ohm
R64 0 ohms / 0 ohms
R67 0 ohms / 0 ohms
R85 0 ohms / 0 ohms
R88 0 ohms / 0 ohms
D1: 447 ohm / open
D2: 3.1 ohm / 3.1 ohm
D3: 447 ohm / open
D4: 3.1 ohm / 3.0 ohm
Sounds like my issue here is D2 and D4 are shorted, so my solution is to remove the 2 diodes and the drive should work again? or do they need to be replaced?
Remove D4. It is probably making D2 look bad because they are in parallel.
Removed it and my drive is accessible. Thanks friend.
I have to ask how 19V gets into a USB box which is designed at 5V
Many coaxial power adapters have different voltages while being the same size, the mini pc i had this external bay hooked up to was 19v, and the bay was 12v, while moving it i accidentally plugged the wrong one into the external bay. Seems to be the case with almost everyone who has fried these.
The “USB box” for a 3.5" drive is a 12V device. It is not powered from the USB port. USB is only used for signalling.
Users typically insert a 19V barrel plug from a laptop adaptor.
I use the supplied PSU with my USB storage boxes. My 5-disk Orico box has 12V 6.5A which handles hard disks fine.
The PSU connector is a 4-pin DIN type connector which makes it unlikely to be confused for barrel or USB. The brick also has a blue LED to show its powered up as well.
My single disk box has a barrel connector but I put a tag on it and the brick has power label which some do not have.
I suggest also labeling power cables etc for safety.
Those DIN pinouts are not standardised. Be very careful if you have two of them.
https://www.hddoracle.com/viewtopic.php?f=56&t=2545&p=18706&hilit=din+pinout#p18706
I agree that DIN plugs are not standardized. Only USB PD is standardized but it has its own shortcomings.
Thunderbolt is designed to support 6 deep daisy chained devices. USB-C is more or less in the same realm. USB PD passthrough is in the PD standard.
