Hey all, just made an account here to ask this question, hoping that’s okay
. I am looking for some help.
I have 4 6TB WD Red drives in an enclosure that I’ve been using as a ZFS pool in RAIDZ1, the ZFS equivalent of RAID5. Well, I was recently redoing some cabling and configuration of my homelab, and wouldn’t you know it, I accidentally plugged in the wrong cable and sent 24V right through the enclosure instead of 12V. Now 2 of the drives won’t spin up, the other two come online fine and I can see them connected, but these two drives make a single noise that sounds like an attempt to start spinning and then they cut out, and nothing I do will make them spin up or register in any enclosure or with any cable. Since this is a RAID5 configuration and I’ve lost 2 drives, unless I can get at least one back I’m SOL.
I’ve been doing a lot of searching and reading the last couple of days since this happened, and I’ve come across a lot of threads here and other places on the web which mostly feature the user @fzabkar helping people figure out how to fix or bypass the shorted components of their drive PCBs after making similar mistakes to my own. Unfortunately, my PCB looks different from any of the photos I’ve seen in those threads, and I lack the electrical knowledge to figure out on my own which components I should be testing and how I might fix these drives. I’ve brought the drives to two separate local computer repair shops, where technicians at both have told me PCB damage is not something they deal with. One even took the drives and ran them through their diagnostics just in case I had misdiagnosed the issue, and they weren’t able to get the drives to spin up either.
As far as I can tell, y’all here are my last hope. Especially @fzabkar, if you’re reading this, since from my Googling you seem like you might be the only person on the Internet who actually understands these drives. I don’t need to “fix” them fully, if I can get even one to spin up and read then I can bring my RAID back online and swap out the drives one by one for new undamaged ones. Any help at all you can provide would be much appreciated, and if I can provide any more information please ask and I will. I’ve got a digital multimeter around here somewhere I can take readings with. I tried to include a ton of photos of the drives and PCBs, but apparently new users can only include two images per post, so I’m also including a link to a public Google Drive folder with many more images of both drives and PCBs, I hope that is okay. As far as I can tell the drives are identical, and there is no difference in behavior between the two either.
Thank you in advance to anyone for any help at all you are able to provide!
>>>More Images (Google Drive link)<<<
