Hi, i bought the MCH about a year ago and it worked great. 6 months ago, a weird thing happened and the server downgraded its firmware from 8.11.0-113 to 8.10.2-100. since then I cant update the firmware and its stuck. I have tried everything: rebooting and waiting a week, searching the ota log in the debug (but it was missing).
the last time it tried to update, it run into some problems i dont understand, and he tried to update 5 times but failed, then it stopped running the updating service for almost half a year.
If you have any idea what would be the problem please respond!
Im attaching the latest log i pulled and the last otalog from 11/30/2022
https://drive.google.com/drive/folders/1bb1jTw_eFa-yxGgTHbvRfXGvmtVV4P_c?usp=sharing
Hi @Tomerkidron1 ,
If the firmware does not update, connect the My Cloud Home to a different network.
Please refer to article My Cloud Home Firmware Update Instructions:
Please contact the WD Technical Support team for best assistance and troubleshooting:https://support-en.wd.com/app/ask
NoPlex
March 26, 2023, 2:40pm
3
This appears to be the infamous READ FPDMA QUEUED and WRITE errors from the My Cloud Home shingled magnetic recording (SMR) HDD. Backup data and then reset (wipe with 60 seconds reset) may help.
60 00 08 00 e0 00 00 16 20 94 e0 40 08 15:44:48.663 READ FPDMA QUEUED
61 00 48 00 c8 00 00 c5 97 4a c0 40 08 15:44:48.626 WRITE FPDMA QUEUED
If HDD data can’t be backup and data recovery is needed, try this suggestion if you are able:
Don’t want to give you any false hope here and I am no expert in data recovery from hard drives, but some reading of the subject suggested that this is due to the SATA cable (no such cable in the MCH) or SATA controller on the mainboard - which means if you shuck the MCH HDD and plug it into a PC SATA port where the PC can also boot from a USB-Linux recovery flash drive, you may be able to get a lot of data back. A proper SATA port is much better and faster than a USB-SATA adapter that you can…
This is smartctl_ctl log from the link you posted:
smartctl 6.6 2017-11-05 r4594 [aarch64-linux-4.9.266] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF READ SMART DATA SECTION ===
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 479 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 479 [22] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 16 20 94 e0 40 00 Error: UNC at LBA = 0x162094e0 = 371234016
Commands leading to the command that caused the error were:
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 08 00 b8 00 00 00 0b ab f8 40 08 15:44:48.626 READ FPDMA QUEUED
60 00 08 00 b0 00 00 00 95 11 18 40 08 15:44:48.626 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 15:44:48.583 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
Error 478 [21] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
60 00 08 00 00 00 00 16 20 94 e0 40 08 15:44:46.332 READ FPDMA QUEUED
60 00 08 00 e8 00 00 00 95 11 18 40 08 15:44:46.332 READ FPDMA QUEUED
60 00 08 00 e0 00 00 00 0b ab f8 40 08 15:44:46.332 READ FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 15:44:46.289 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 15:44:46.288 IDENTIFY DEVICE
Error 477 [20] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
60 00 08 00 48 00 00 16 20 94 e0 40 08 15:44:44.072 READ FPDMA QUEUED
61 00 08 00 28 00 00 c5 97 4a 20 40 08 15:44:44.042 WRITE FPDMA QUEUED
61 00 08 00 18 00 00 e9 18 27 88 40 08 15:44:44.042 WRITE FPDMA QUEUED
60 00 08 00 10 00 00 00 95 e7 30 40 08 15:44:44.042 READ FPDMA QUEUED
60 00 08 00 08 00 00 00 95 6a 48 40 08 15:44:44.042 READ FPDMA QUEUED
Error 476 [19] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
60 00 08 00 b0 00 00 00 0b ab f8 40 08 15:44:41.827 READ FPDMA QUEUED
60 01 00 00 a8 00 00 00 0a 3d 88 40 08 15:44:41.827 READ FPDMA QUEUED
60 00 08 00 a0 00 00 00 95 6a 48 40 08 15:44:41.827 READ FPDMA QUEUED
60 00 08 00 98 00 00 00 95 e7 30 40 08 15:44:41.827 READ FPDMA QUEUED
60 00 08 00 18 00 00 16 20 94 e0 40 08 15:44:41.806 READ FPDMA QUEUED
Error 475 [18] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
40 -- 51 00 00 00 00 16 20 95 80 40 00 Error: UNC at LBA = 0x16209580 = 371234176
60 00 08 00 38 00 00 16 20 94 88 40 08 15:44:39.556 READ FPDMA QUEUED
60 00 08 00 a8 00 00 16 20 94 80 40 08 15:44:39.507 READ FPDMA QUEUED
60 00 08 00 98 00 00 00 0c a0 18 40 08 15:44:39.507 READ FPDMA QUEUED
60 01 00 00 90 00 00 16 20 95 80 40 08 15:44:39.507 READ FPDMA QUEUED
60 00 08 00 88 00 00 00 95 7c 50 40 08 15:44:39.507 READ FPDMA QUEUED
Error 474 [17] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
60 01 00 00 30 00 00 16 20 94 80 40 08 15:44:37.242 READ FPDMA QUEUED
60 01 00 00 28 00 00 16 20 93 80 40 08 15:44:37.242 READ FPDMA QUEUED
60 01 00 00 20 00 00 16 20 92 80 40 08 15:44:37.241 READ FPDMA QUEUED
60 01 00 00 18 00 00 16 20 91 80 40 08 15:44:37.240 READ FPDMA QUEUED
60 01 00 00 10 00 00 16 20 90 80 40 08 15:44:37.239 READ FPDMA QUEUED
Error 473 [16] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
40 -- 51 00 00 00 00 2c 43 1e 88 40 00 Error: UNC at LBA = 0x2c431e88 = 742596232
60 00 08 00 88 00 00 2c 43 1e 88 40 08 15:36:07.841 READ FPDMA QUEUED
60 01 00 00 80 00 00 00 0c a2 f0 40 08 15:36:07.811 READ FPDMA QUEUED
60 01 00 00 08 00 00 00 0b 7b 80 40 08 15:36:07.809 READ FPDMA QUEUED
61 03 38 00 00 00 00 00 95 09 68 40 08 15:36:07.799 WRITE FPDMA QUEUED
60 00 80 00 f0 00 00 00 0b ab e8 40 08 15:36:07.790 READ FPDMA QUEUED
Error 472 [15] occurred at disk power-on lifetime: 13492 hours (562 days + 4 hours)
60 00 08 00 10 00 00 2c 43 1e 88 40 08 15:36:05.566 READ FPDMA QUEUED
61 00 a8 00 00 00 00 e9 17 a4 a0 40 08 15:36:05.566 WRITE FPDMA QUEUED
27 00 00 00 00 00 00 00 00 00 00 e0 08 15:36:05.523 READ NATIVE MAX ADDRESS EXT [OBS-ACS-3]
ec 00 00 00 00 00 00 00 00 00 00 a0 08 15:36:05.522 IDENTIFY DEVICE
ef 00 03 00 46 00 00 00 00 00 00 a0 08 15:36:05.522 SET FEATURES [Set transfer mode]
