Hi guys.
Hope someone can help as Im pulling my hair out. Ive been watching films through my WD Network hard drive for years now and all of a sudden both tvs in my house upon selecting the drive comes up saying theres no content on the drive.
I can see that all the content is indeed still there on the drive using my PC (and can still move content freely around).
*Note: When I go on the Drives IP it tells me all the files and amount of used space. When I click on it through explorer I get the Twonky server and it states Zero content?
Ive rebooted the hardrive but that hasnt done the trick. Any advice?
EDIT:
Just incase someone else has this problem I have now got the solution:
Someone named @Stampey (https://community.wd.com/u/Stampey) found it and saved my life! Thank you youre a saviour!
This may be too late for you now but I have only just bought a unit but it may be of use if anyone else experiences the same problem.
I had the issue when I set mine up (firmware v04.01.02-417) ie. “no media files in DLNA server list (the media database,on the other hand is OK)” so the dashboard knew the content was there.
I managed to resolve it by accessing the twonky server using a browser (address http:// ipaddress :9000 not mycloud:9000 as this didn’t work for me) and going to the “sharing” section. The share was shown as “/Public” so I hit the browse button and remapped the share and it showed up as “/shares/Public”, other folder I manually typed “/shares” in front
Once this was done it went off and found the content that I had on the drive and listed it in the DLNA Media Server section, I also did do a rescan just to be sure.
Hope this helps someone before they get as frustrated as I’ve been !!
