When I try to update Firmware either online or using a file, it get stuck on upgrading screen
2.31.149
I have EX2 Ultra. Please guide.
My current version is 2.30.196
2.31.149
Hi nitingautam,
We have sent a message. Please check your Community Message Inbox.
Thank you this is fixed now. Able to apply updates to my cloud. Not sure what changed this after couple of days I again tried same steps after reboots and it picked up latest firmware. This can be closed.
I have the same problem. Can you share the solution? I see you were sent a direct message from WD support - what was the advice?
Thanks!
I have the same problem today.
Why to send a response via inbox if the solution could be for all of us?
Hello everyone,
I’m facing the same issue. My Cloud EX2 Ultra is stuck upgrading the firmware (current 2.40.157). The upgrade process started, but it’s been two days now without progress and I am unable to hybernate or reboot the drive; when doing so I get a message saying that such actions are not permitted during firmware upgrade.
Any ideas how to resolve this?
Thank you,
Ahmed
Please contact support and provide the My Cloud system logs
