I recently had a HDD fail and replaced it with a new one of the same make and model. Since the rebuild the status LED on the front for that bay has been red. The Drives page says the drive is good. Any suggestions?
Assuming the hard drives have been properly initialized, they should be checked for errors. To verify the hard drive type and S.M.A.R.T. status, use either of the following options.
Option 1:
Install the “Get S.M.A.R.T.
” app for My Cloud OS5 NAS devices, available from the list below. The preformatted results can be easily copied and posted to the forums for further analysis if desired. The “Get S.M.A.R.T.
” app also updates the smartctl
database and reports the drive self-test status.
My Cloud OS5 Apps Matrix (Third-Party)
Option 2:
Enable SSH, then run the following commands, one at a time. The results can be easily copied and posted to the forums for further analysis if desired.
smartctl -a /dev/sda;
smartctl -a /dev/sdb;
smartctl -a /dev/sdc;
smartctl -a /dev/sdd;
Device:
Firmware Version: 5.27.157
Hardware Version: WDMyCloudDL4100
Model Code:
Disk 1:
Device Path: /dev/sda
Model Family: Western Digital Red
Device Model: WDC WD60EFRX-68L0BN1
Self-Test: PASSED
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 197 196 021 - 9133
4 Start_Stop_Count -O--CK 092 092 000 - 8944
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 039 039 000 - 44980
10 Spin_Retry_Count -O--CK 100 100 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 93
192 Power-Off_Retract_Count -O--CK 200 200 000 - 82
193 Load_Cycle_Count -O--CK 197 197 000 - 9751
194 Temperature_Celsius -O---K 118 110 000 - 34
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
Disk 2:
Device Path: /dev/sdb
Model Family: Western Digital Red Pro
Device Model: WDC WD6002FFWX-68TZ4N0
Self-Test: PASSED
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance P-S--- 138 138 054 - 100
3 Spin_Up_Time POS--- 159 159 024 - 415 (Average 413)
4 Start_Stop_Count -O--C- 091 091 000 - 37375
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 0
7 Seek_Error_Rate PO-R-- 100 100 067 - 0
8 Seek_Time_Performance P-S--- 128 128 020 - 18
9 Power_On_Hours -O--C- 092 092 000 - 57874
10 Spin_Retry_Count PO--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 120
192 Power-Off_Retract_Count -O--CK 069 069 000 - 37564
193 Load_Cycle_Count -O--C- 069 069 000 - 37564
194 Temperature_Celsius -O---- 153 153 000 - 39 (Min/Max 21/46)
196 Reallocated_Event_Count -O--CK 100 100 000 - 0
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 0
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Disk 3:
Device Path: /dev/sdc
Model Family: Western Digital Red (SMR)
Device Model: WDC WD60EFAX-68JH4N0
Self-Test: PASSED
1 Raw_Read_Error_Rate POSR-K 100 253 051 - 0
3 Spin_Up_Time POS--K 228 227 021 - 3558
4 Start_Stop_Count -O--CK 100 100 000 - 15
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 096 096 000 - 3222
10 Spin_Retry_Count -O--CK 100 253 000 - 0
192 Power-Off_Retract_Count -O--CK 200 200 000 - 2
193 Load_Cycle_Count -O--CK 200 200 000 - 13
194 Temperature_Celsius -O---K 125 118 000 - 25
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Disk 4:
Device Path: /dev/sdd
Self-Test: PASSED
1 Raw_Read_Error_Rate PO-R-- 090 090 016 - 2097188
2 Throughput_Performance P-S--- 137 137 054 - 104
3 Spin_Up_Time POS--- 165 165 024 - 398 (Average 399)
4 Start_Stop_Count -O--C- 098 098 000 - 9727
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 1
9 Power_On_Hours -O--C- 092 092 000 - 59727
12 Power_Cycle_Count -O--CK 100 100 000 - 118
192 Power-Off_Retract_Count -O--CK 091 091 000 - 11762
193 Load_Cycle_Count -O--C- 091 091 000 - 11762
194 Temperature_Celsius -O---- 162 162 000 - 37 (Min/Max 20/47)
196 Reallocated_Event_Count -O--CK 100 100 000 - 1
197 Current_Pending_Sector -O---K 100 100 000 - 2472
198 Offline_Uncorrectable ---R-- 076 076 000 - 6712
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
Disk 1 is the one with the red LED.
Disk 1 shows no obvious signs of problems. Note that disk numbers do not necessarily correspond to slot numbers or locations.
Disk 3 uses SMR technology, which is not suitable for use in RAID arrays.
Disk 4 is failing.
Raw_Read_Error_Rate - 2097188
Reallocated_Sector_Ct - 1
Reallocated_Event_Count - 1
Current_Pending_Sector - 2472
Offline_Uncorrectable - 6712
Thanks for the info. Looks like I will be ordering new drives.
You should create backups prior to swapping drives and doing multiple RAID rebuilds.
Also, I made a minor change to the “Get S.M.A.R.T.
” NAS app, so disk numbers should now correspond to the actual slot number or drive bay. Simply download and install the app again to see the new results. In your case, I suspect that disk 4 is actually the HDD in bay 1 with the red LED.
