What is the maximum SD card size for the Passport Wireless Pro?
I searched for that here and didn’t find the answer.
Hi @DOUGLAS_JENSEN - My Passport Wireless Pro will support SD card capacities up to 512GB, such as the 512GB SanDisk Extreme Pro SD UHS-I Card. Happy shooting!
For a list of the supported devices, you can reference the article below.
https://support.wdc.com/knowledgebase/answer.aspx?ID=11737
Great news, @DOUGLAS_JENSEN - we just updated our compatibility list! This will now show that the SanDisk 512GB SD card is absolutely supported.
https://support.wdc.com/knowledgebase/answer.aspx?ID=11737#wirelesspro
