Web file viewer is missing? it will be supported? transmission problem
i recently updated to os5.
i can’t find web file viewer on app. it’s unsopported?
then i downloaded transmission but i can’t find the right folder to download files in.
thanks for ur help
Please refer to the following KBA: Error
Web file viewer isn’t even available for admin users as the KB suggests, my understanding was it’s been deprecated in OS5, can you clarify please? I would like for this app to be available again. Thanks
My Cloud IS NOT a good alternative to Web File Viewer! You can’t copy between shares and you can’t edit OS structure to install plex modules. I’m looking at doing a brutal reversion to OS3 because of the function lost with the OS5 update, especially exasperated by the like of the web file viewer. I feel WD really doesn’t understand how folks are using their devices…
