I have a ton of home movies that are in mkv format on my external hard drive. I have each video folder set up with a thumbnail as well and everything is labeled the same. For example:
Folder
Folder.mkv
When I plug my hard drive directly into my WDTV player all is well. the jpeg shows up as the thumbnail poster.
Now i just plugged that hard drive into my Netgear WNDR3400 so I could acess the movies over my network. Now when all the movies load i get no thumbnail picture for the folder it just shows the movie real. When i click the folder it opens and shows the jpeg picture and the movie with a picture. How do i get the thumbnail to show up over a network?
Im a little confused isant that the way I have it set up? With the folder labeled the way it is below, and when you open the folder the items are labeled below in the pictures. I have included 2 picture this time to show you. (I am aware the video file says avi I was just using it as an example)
