Hi, I got a 1TB Wireless Passport this week.
Few issues :
It says, update firmware, but nothing happens, when I click.
I have AUTO COPY feature enabled in the settngs page, but when I insert the card, the auto copy doesnt happen.
If I connect the card and then connect the drive wirelessly to my computer, and click on COPY< then copy happens fine, but in the end shows some error.
If you do not have the complete MPW user manual you need to find it on your drive or download it from WD. Without it, you are utterly clueless and wasting your time and others who try to help you.
Hi could somebody please help me… I cant access my files stored in the external drive… the light is on when I plug it in my pc but it wont appear on the windows explorer but it appear on the safely remove hardware and eject media
