WD Tv Play 4TB hard drive playback problems
I am thinking of buying WD TV Play but some owners have said they have problems with using 4TB hard drives, that the player can’t see it or doesn’t work properly with them. Can any users give feed back please thanks
I know someone that has problems with just 3TB, so I’d say 4TB is out of the question. WD says it works but if you read the board you’ll tell it’s hit or miss.
It’s 2.5" or 3.5" BOX ?? try to connect your power supply if it’s possibile or try to use a powered hub usb…
