Hi, i bought WD MyNet N900C from a local retailer it does not have internal storage drive but thats not the issue.
I put 80 GB WD drive as testing it picks up the drive then i add to my pc, then i try to see the of data transfer rate i upload 2 GB file via ftp, it goes good at 300 Mbps not bad for me but then it stucks and then restarts itself.
Sometimes i have to manually plug the drive out then plug it again. I have formatted it as ext.
I try to upgrade the firmware but no luck, same issue.
Then another issue is 5Ghz radio is on low bands i can not see channels above 40, my mobile phones can not connect to it.
