WD Elements 3tb hard drive Power Plug
I recently purchased a WD Elements 3tb hard drive with usb 2.0. I find it very annoying that I have to plug it into a powerpoint in order for it work, so I was wondering is there a something I can buy that will give an output of 12v but has a usb connecter on it so I can plug it into my computer instead of a powerpoint?
You need a USB powered drive for that the one you bought is externally powered.
Joe
Thanks so there is no way to power it without a power supply?
