Using a 4TB MyCloud for Time Machine backups for multiple computers
As the subject line says…
I’ve just set up a My Cloud device on my network, with the intention of using Time Machine on three separate Macs in our house.
Will this work? Do I need to do anything special?
I’m a little nervous about pointing each Mac’s Time Machine at the same share on the My Cloud…I’m just not sure what will happen.
But, I don’t see a way to set up more than one Time Machine share on the My Cloud.
Thanks,
Mark
Can you use a My Cloud as a backup location for multiple computers? Yes.
However, do a forum search for Time Machine. Some are having problems (seems to be mostly El Capitan related) getting the Time Machine backup to work properly. Also there is a huge El Capitan thread that discusses a variety of issues with the My Cloud. There are some possible workarounds. See the following two threads/posts.
http://community.wd.com/t/updated-solution-to-osx-10-11-5-smb-error-36/165230/4
http://community.wd.com/t/permissions-access-issue/166703/2
Generally it is best to have the computer connected via Ethernet cable to a Gigabit router/switch to get the fastest backup speed. Trying to backup over WiFi typically is slower than wired Ethernet.
