Hi guys,
I’m hoping to drum up some support for theme developers with this post. Your support not only is of benefit to their time and efforts, but yours as well if you enjoy using themes. I see many posts about theme compatibility issues for both the SMP and HUB. Some of that confusion could be addressed if WD were to fix this issue with a FW update. It would be a big step in the right direction.
As some of you are aware we cannot utilize true .png’s on the current firmware for the SMP or HUB. The SMP was never able to display true .png’s and HUB owners are required to do a firmware rollback to use them. Most theme developers use .png instead of .jpg, so you will never get the theme to look as it should unless you own a HUB and you’re on the correct FW.
Many of you may be content with the default theme, but there are those of us that aren’t. I can tell by the amount of theme thread views that enough of you DO care, yet where is the support for those that develop them? Also, as a consumer why should you settle for a company breaking a feature in a firmware update when the sole intention of said firmware update was to ADD MORE, not take away.
Why should you care?
1.) High quality cover art thumbnails.
2.) Transparency effects.
3.) The ability to enjoy a cleaner much more robust UI experience without having to sacrifice the latest firmware features and bug fixes.
4.) The opportunity to help theme developers who have invested enormous amounts of their time to bring you something special.
Even if you don’t use themes or care, we would greatly appreciate some of your time to check the link below and make a post. It will only take 1 minute of your time.
Even a very basic comment could go a long way in grabbing Western Digitals attention. I.e
‘As an SMP user I would like to see this issue addressed in a future FW update.’
I’m sure there have been quite a few issue reports regarding this problem (I have read some of them) but I picked Tinwarbles because It’s the most detailed I have seen and thus most likely to be investigated.
I know I haven’t been part of this community for very long, but I put a lot of my time into helping others, so please give back.
Lets band together to make this happen guys! Don’t allow WD to stifle the great creative community we have!
Link to issue: http://community.wdc.com/t5/WD-TV-Live-Hub-Issue-Reporting/PNG-s-do-not-display-correctly-for-files-folder-thumbnails/idi-p/268062
