Setting up Safepoint to mirror local MBL to an offsite MBL
I’m trying to figure out if the following is possible. I want to buy two MBL’s. I’d have  MBL A at House A and the second, MBL B, at House B.
House A  → Backup → MBL A → Safepoint -->> MBL B
House B  → Backup → MBL B → Safepoint -->> MBL A
This would create  a local backup for each house, as well as a backup image at the second house…protection against fire/theft, etc for each location.
Is this possible?
I guess you mean safepoint? If that is the case then no, safepoints only work on your local network, but you should be able to use wd2go to map MBL A on computer B and use a third party program that allows you to backup files to a shared folder. Check the link below for more info.
http://wdc.custhelp.com/app/answers/detail/a_id/7080/session/L3RpbWUvMTM0NDk3ODI2NC9zaWQvclA3bi1IM2w%3D
Your right, I meant Safepoint…I updated it!
What 3rd party software would you recommend? It would be nice if this feature was added to MBL. I read Iomega has this feature built into there Cloud Edition drive.
I suppose another option would be to just copy the contents manually from MBL A to MBL B through wd2go…but with 100’s of GB of data that would be a time consuming transfer everytime you wanted to update the offsite drive. I was hoping for an automatic solution that would only transfer incremental changes.
