Same for WD Scorpio Blue WD5000BEVT
I have the same problem with my internal Scorpio Blue WD5000BEVT-80A0RT0. Current Firmware is 01.01A01
The APM value was at 60h and should also be 80h! Please provide a firmware!
It took me several weeks to find out why exactly my ASUS notebook always freezes for a few seconds in different applications. In the Windows 7 Resource Monitor you could trace those hangs, when the last accessed file had a response time of ~3000ms. Then always the HDD spinned up again.
My prior solution was to produce a constant data read with playing a local sound file in loop (however with volume at 0%)
→ Just to be able to work normally!!!
Please fix this little setting in your firmware! Thanks
I can’t understand why WD is keeping silence???
Could anyone WD’s engineer comment this problem and give some solution?
HELLO WD, WHERE ARE YOU??? IT’S NOT A TIME TO PLAY HIDE’N’SEEK!!!
We are paid money for your drives…for usable drives! But it is not usable with 8 seconds of idle time.
Common we are all waiting for the official comments and new firmware. It is really gracelessly!
Best bet is to immediately return a faulty drive, if WD hasn’t done anything by now, it ain’t gonna happen.
This is just a users forum. If it’s a plain HD why are you posting in External HD area? It’s for externals made  by WD not some homemade one.
Joe
