Replacement of hard drive
Hey… Can i place cable of defective drive into the replacement box sent to wd… Please reply me fast
Hi, you don’t need to include the cables in the box, just the faulty drive. You can see this information on the packaging instructions. “Remove and keep third party cases1, cables, brackets2, manuals, and diskettes.” Check the link below.
http://support.wdc.com/warranty/rmapacking.asp?lang=en
