Release EX2 Ultra using for EX2?
Hallo togehter
what is the differences between EX2 and EX2 Ultra?
Thank
Steve
Hello, the EX 2 ultra is the second generation of the My Cloud EX 2, they have different hardware, the EX 2 ultra is faster and has more RAM.
For further information you can go into the links below.
EX 2: http://www.wdc.com/wdproducts/library/AAG/ENG/4178-706093.pdf
EX 2 Ultra: All Products: Shop Hard Drives, SSDs, USBs, & Memory Cards | Western Digital
the last Release update from the Ex2 was last year, but the ultra has a newer version.
is it possible to use the release from the Ultra to the EX2?
the release before are simular to each other.
Hi, unfortunately no, hardware being different means the the code or firmware most likely is different and you might damage your drive.
I wouldn’t hold your breath. They never fixed the stupid LED behaviour despite EVERYONE hating it.
From my point,
i belief, think, there is a “more less normal” Unix/Linux distribution behind, with a web interface from WD
that should not be a problem to upgrade the system.
but I am a scaredy-cat :frowning:
