Purchased Two 8TB MyCloud. Need configuration help please
I’ve just received both new devices and wish to make both identical, so I’ve transfered all the files on the first device under the shared music folder.
In order to connect the second device to my network, is there anything I should do to the first one’s config? I’m guessing both default config will create some sort of conflict. Thx in advance!
Each My Cloud will need a unique name.
Some are reporting problems with remote access (outside of their local network) to the second My Cloud when they run two (or more) on their local network.
