Hi
I’ve had my G-Speed Studio R shutdown and give the following warning"PSU 5V power is out of the threshold range". I tried rebooting the device which set off a warning buzz and the G logo flashed red then it shutdown again. I then tried the unit with another power cord and it’s working fine, however under the component list it states that the current voltage is not present for 5.0v.
Any advice as to whether I should continue to use the device would be appreciated and if it can be or needs to be fixed.
