Problem with my WD TV model WDBHG70000NBK-HESN not reading hard drive
So i just bought this earlier this week and it does not read all the files on the Hard Drive.  Only pops up with 5 movie files instead of the several hundreds that are on there.   Hard drive I am using is Western Digital MyBook Essential 3.0 External HD 3TB.
Player model is : WDBHG70000NBK-HESN
Any advice is appreciated.
  • Are you connecting the drive to the front or back USB port?
  • Which firmware version are you using?
  • What’s the format of your movies?
  • If you connect another drive do you encounter the same issue?
  • Is the media library on?
