Problem with DLNA and a WD TV Play
I used my WD TV Live Hub and a WD TV Play for many months without a problem, but yesterday the Play does not see the Hub in the network as a DLNA but has found as a TwonkeyMedia but empty.
I have not changed anything in this day …
Also with my iPad and VLC the DLNA is disappeared and i see only the TwonkeyMedia, always empy…
sorry for my bad english
Hello there,
Try to reset the unit to see if this corrects the issue with the DLNA serve since the media server does not appear on the computer or WDTV play reset the Live Hub unit.
Here is a link that will help you with the reset process on the unit:
http://wdc.custhelp.com/app/answers/detail/a_id/3646
Now works!
Thank you very much!
