PR4100 Ethernet Problem? Solved
New WD PR411 user. I am doing my 2nd backup from computer 2, the first ( computer 1) one last week went quick and I was happy with the throughput speed. This was before the last firmware update i might note. My task manager show the send speed as 96.0±Mbps to the WD Nas. however the Rx/Recieve speed is only 1.8 Mbps so my 237 GB BU is going to take over 3 days. The first one on computer no 1 was done in a matter of hours ( about 2 if i recall ) Same disk in the WD Nas a WD Red 6TB ( 4 Total )
Any Ideas ANYONE?
/////////////////////// Not all Cat 7 cables are created equally////////////////
So my other computer was getting a 1Gps connection from the router to the network/computer. computer 2 ( Same cable by the way, both brand new…) was only allowing a 100mbps through, new cable ( different brand… love amazon 1 day delivery) Fixed that both are know 1 Gbps connections… and speeds are totally acceptable. I am know a better troubleshooter… But I tended to accept the NEW cables were both GOOD… Oh well, another great lesson. happy holidays to all…
