Pink led appears after power failure
Hi
after a power failure, Bay3 led turn to blue/red (pink) at the same time.
HDD is changed. From GUI, rebuilding is complete. Led is still pink.
mdadm was the alternate solution. Remove and add HDD by command. Rebuilding happened then but Led is still pink.
So, give me an idea, please.
regards
here is output of “dmesg”:
Linux version 3.2.40 (kman@kmachine) (gcc version 4.6.4 20120731 (prerelease) (Linaro GCC branch-4.6.4. Marvell GCC 201301-1645.aee66e26) ) #1 Fri Nov 16 11:50:03 CST 2018
CPU: Feroceon 88FR131 [56251311] revision 1 (ARMv5TE), cr=00053977
CPU: VIVT data cache, VIVT instruction cache
Machine: Marvell xCat98DX Development Board
Memory policy: ECC disabled, Data cache writeback
On node 0 totalpages: 16384
free_area_init_node: node 0, pgdat c06daf14, node_mem_map c0790000
Normal zone: 16 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 16368 pages, LIFO batch:3
pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
pcpu-alloc: [0] 0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16368
Kernel command line: root=/dev/ram console=ttyS0,115200 max_loop=32 :::DB88FXX81:egiga0:none
PID hash table entries: 2048 (order: -2, 8192 bytes)
Dentry cache hash table entries: 65536 (order: 3, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 2, 131072 bytes)
allocated 262144 bytes of page_cgroup
please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
Memory: 512MB = 512MB total
Memory: 513184k/513184k available, 11104k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff8000 ( 32 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xe0800000 - 0xfa800000 ( 416 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0668000 (6528 kB)
.init : 0xc0668000 - 0xc06a0000 ( 224 kB)
.data : 0xc06a0000 - 0xc06dc680 ( 242 kB)
.bss : 0xc06dc6a4 - 0xc0788598 ( 688 kB)
SLUB: Genslabs=16, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:114
sched_clock: 32 bits at 200MHz, resolution 5ns, wraps every 21474ms
Console: colour dummy device 80x30
Calibrating delay loop… 1980.82 BogoMIPS (lpj=9904128)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 4096
Initializing cgroup subsys cpuacct
Initializing cgroup subsys memory
CPU: Testing write buffer coherency: ok
xor: measuring software checksum speed
arm4regs : 169.600 MB/sec
8regs : 144.000 MB/sec
32regs : 160.000 MB/sec
xor: using function: arm4regs (169.600 MB/sec)
NET: Registered protocol family 16
Marvell Development Board (LSP Version linux-3.2.40-2013_Q1.2p4 (32KB SW Page Size))
Kirkwood: MV88F6282-Rev-Unsupported, TCLK=200000000.
Feroceon L2: Enabling L2
Feroceon L2: Cache support initialised.
Kirkwood PCIe port 0:
link up
Kirkwood PCIe port 1:
link up
PCI: bus0 uses PCIe port 0
pci 0000:00:00.0: [11ab:6282] type 0 class 0x000580
pci 0000:00:00.0: reg 10: [mem 0xf1000000-0xf10fffff 64bit pref]
pci 0000:00:00.0: reg 18: [mem 0x00000000-0x1fffffff]
pci 0000:00:00.0: supports D1 D2
pci 0000:00:01.0: [11ab:7042] type 0 class 0x000100
pci 0000:00:01.0: reg 10: [mem 0x14000000-0x140fffff 64bit]
pci 0000:00:01.0: reg 18: [io 0x0000-0x00ff]
PCI: bus0: Fast back to back transfers disabled
PCI: bus1 uses PCIe port 1
pci 0000:01:00.0: [11ab:6282] type 0 class 0x000580
pci 0000:01:00.0: reg 10: [mem 0xf1000000-0xf10fffff 64bit pref]
pci 0000:01:00.0: reg 18: [mem 0x00000000-0x1fffffff]
pci 0000:01:00.0: supports D1 D2
pci 0000:01:01.0: [1b6f:7023] type 0 class 0x000c03
pci 0000:01:01.0: reg 10: [mem 0x98000000-0x98007fff 64bit]
pci 0000:01:01.0: supports D1 D2
pci 0000:01:01.0: PME# supported from D0 D1 D2 D3hot
pci 0000:01:01.0: PME# disabled
PCI: bus1: Fast back to back transfers disabled
pci 0000:01:01.0: BAR 0: assigned [mem 0xe8000000-0xe8007fff 64bit]
pci 0000:01:01.0: BAR 0: set to [mem 0xe8000000-0xe8007fff 64bit] (PCI address [0xe8000000-0xe8007fff])
pci 0000:00:01.0: BAR 0: assigned [mem 0xe0000000-0xe00fffff 64bit]
pci 0000:00:01.0: BAR 0: set to [mem 0xe0000000-0xe00fffff 64bit] (PCI address [0xe0000000-0xe00fffff])
pci 0000:00:01.0: BAR 2: assigned [io 0x1000-0x10ff]
pci 0000:00:01.0: BAR 2: set to [io 0x1000-0x10ff] (PCI address [0x1000-0x10ff])
MV Buttons Device Load
bio: create slab at 0
raid6: int32x1 58 MB/s
raid6: int32x2 103 MB/s
raid6: int32x4 157 MB/s
raid6: int32x8 212 MB/s
raid6: using algorithm int32x8 (212 MB/s)
vgaarb: loaded
SCSI subsystem initialized
libata version 3.00 loaded.
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new interface driver ethub
usbcore: registered new device driver usb
Switching to clocksource orion_clocksource
NET: Registered protocol family 2
IP route cache hash table entries: 8192 (order: 0, 32768 bytes)
TCP established hash table entries: 16384 (order: 2, 131072 bytes)
TCP bind hash table entries: 16384 (order: 1, 65536 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP reno registered
UDP hash table entries: 2048 (order: 0, 32768 bytes)
UDP-Lite hash table entries: 2048 (order: 0, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 32 bytes, default 32
Trying to unpack rootfs image as initramfs…
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 1920K
cesadev_init(c0670e44)
MV Buttons Driver Load
Loading Marvell Ethernet Driver:
o Cached descriptors in DRAM
o DRAM SW cache-coherency
o 2 Giga ports supported
o Single RX Queue support - ETH_DEF_RXQ=0
o Single TX Queue support - ETH_DEF_TXQ=0
o TCP segmentation offload (TSO) supported
o Large Receive offload (LRO) supported
o Receive checksum offload supported
o Transmit checksum offload supported
o Driver ERROR statistics enabled
o Proc tool API enabled
o SKB Reuse supported - (Disabled)
o Rx descripors: q0=128
o Tx descripors: q0=532
o Loading network interface(s):
o egiga0, ifindex = 2, GbE port = 0
o egiga1, ifindex = 3, GbE port = 1
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 8192 (order 0, 32768 bytes)
squashfs: version 4.0 (2009/01/31) Phillip Lougher
Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
NTFS driver 2.1.30 [Flags: R/O].
fuse init (API version 7.17)
SGI XFS with security attributes, large block/inode numbers, no debug enabled
msgmni has been set to 1006
async_tx: api initialized (async)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered (default)
Initializing ths8200_init
Initializing dove_adi9889_init
mv_xor_shared mv_xor_shared.0: Marvell shared XOR driver
mv_xor_shared mv_xor_shared.1: Marvell shared XOR driver
mv_xor mv_xor.0: Marvell XOR: ( xor cpy )
mv_xor mv_xor.1: Marvell XOR: ( xor fill cpy )
mv_xor mv_xor.2: Marvell XOR: ( xor cpy )
mv_xor mv_xor.3: Marvell XOR: ( xor fill cpy )
Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0xf1012000 (irq = 33) is a 16550A
console [ttyS0] enabled
serial8250.1: ttyS1 at MMIO 0xf1012100 (irq = 34) is a 16550A
brd: module loaded
loop: module loaded
sata_mv 0000:00:01.0: version 1.28
PCI: enabling device 0000:00:01.0 (0140 → 0143)
sata_mv 0000:00:01.0: Gen-IIE 32 slots 4 ports SCSI mode IRQ via INTx
scsi0 : sata_mv
scsi1 : sata_mv
scsi2 : sata_mv
scsi3 : sata_mv
ata1: SATA max UDMA/133 mmio m1048576@0xe0000000 port 0xe0022000 irq 9
ata2: SATA max UDMA/133 mmio m1048576@0xe0000000 port 0xe0024000 irq 9
ata3: SATA max UDMA/133 mmio m1048576@0xe0000000 port 0xe0026000 irq 9
ata4: SATA max UDMA/133 mmio m1048576@0xe0000000 port 0xe0028000 irq 9
NAND device: Manufacturer ID: 0x98, Chip ID: 0xda (Toshiba NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Creating 7 MTD partitions on “orion_nand”:
0x000000000000-0x000000100000 : “u-boot”
0x000000100000-0x000000600000 : “uImage”
0x000000600000-0x000000b00000 : “ramdisk”
0x000000b00000-0x00000d800000 : “image”
0x00000dd00000-0x00000ec00000 : “rescue firmware”
0x00000ec00000-0x000010000000 : “config”
0x00000d800000-0x00000dd00000 : “reserve”
sky2: driver version 1.30
ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
etxhci_hcd_131016 0000:01:01.0: Etron xHCI Host Controller
etxhci_hcd_131016 0000:01:01.0: new USB bus registered, assigned bus number 1
etxhci_hcd_131016 0000:01:01.0: irq 10, io mem 0xe8000000
xHCI etxhci_add_endpoint called for root hub
xHCI etxhci_check_bandwidth called for root hub
ethub 1-0:1.0: USB hub found
ethub 1-0:1.0: 2 ports detected
etxhci_hcd_131016 0000:01:01.0: new USB bus registered, assigned bus number 2
ethub 2-0:1.0: USB hub found
ethub 2-0:1.0: 2 ports detected
Initializing USB Mass Storage driver…
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
Orion Watchdog Timer: Initial timeout 21 sec
md: linear personality registered for level -1
md: raid0 personality registered for level 0
md: raid1 personality registered for level 1
md: raid10 personality registered for level 10
md: raid6 personality registered for level 6
md: raid5 personality registered for level 5
md: raid4 personality registered for level 4
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
cpuidle: using governor ladder
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP cubic registered
NET: Registered protocol family 17
8021q: 802.1Q VLAN Support v1.8
Gating clock of unused units
before: 0x008fc3dd
after: 0x00dfc3fd
registered taskstats version 1
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata1.00: ATA-9: WDC WD40PURX-64GVNY0, 80.00A80, max UDMA/133
ata1.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata1.00: configured for UDMA/133
scsi 0:0:0:0: Direct-Access ATA WDC WD40PURX-64G 80.0 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
sd 0:0:0:0: [sda] 4096-byte physical blocks
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
sda: sda1 sda2 sda3 sda4
sd 0:0:0:0: [sda] Attached SCSI disk
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.00: ATA-9: WDC WD40PURX-64GVNY0, 80.00A80, max UDMA/133
ata2.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata2.00: configured for UDMA/133
scsi 1:0:0:0: Direct-Access ATA WDC WD40PURX-64G 80.0 PQ: 0 ANSI: 5
sd 1:0:0:0: [sdb] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
sd 1:0:0:0: [sdb] 4096-byte physical blocks
sd 1:0:0:0: Attached scsi generic sg1 type 0
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
sdb: sdb1 sdb2 sdb3 sdb4
sd 1:0:0:0: [sdb] Attached SCSI disk
ata3: SATA link down (SStatus 0 SControl 300)
ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata4.00: ATA-9: WDC WD40PURX-64GVNY0, 80.00A80, max UDMA/133
ata4.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata4.00: configured for UDMA/133
scsi 3:0:0:0: Direct-Access ATA WDC WD40PURX-64G 80.0 PQ: 0 ANSI: 5
sd 3:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
sd 3:0:0:0: [sdc] 4096-byte physical blocks
sd 3:0:0:0: Attached scsi generic sg2 type 0
sd 3:0:0:0: [sdc] Write Protect is off
sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
sdc: sdc1 sdc2 sdc3 sdc4
sd 3:0:0:0: [sdc] Attached SCSI disk
md: Skipping autodetection of RAID arrays. (raid=autodetect will force)
RAMDISK: gzip image found at block 0
VFS: Mounted root (ext2 filesystem) on device 1:0.
Freeing init memory: 224K
UBI: attaching mtd5 to ubi0
UBI: physical eraseblock size: 131072 bytes (128 KiB)
UBI: logical eraseblock size: 126976 bytes
UBI: smallest flash I/O unit: 2048
UBI: sub-page size: 512
UBI: VID header offset: 2048 (aligned 2048)
UBI: data offset: 4096
UBI: max. sequence number: 103691
UBI: attached mtd5 to ubi0
UBI: MTD device name: “config”
UBI: MTD device size: 20 MiB
UBI: number of good PEBs: 160
UBI: number of bad PEBs: 0
UBI: number of corrupted PEBs: 0
UBI: max. allowed volumes: 128
UBI: wear-leveling threshold: 4096
UBI: number of internal volumes: 1
UBI: number of user volumes: 1
UBI: available PEBs: 30
UBI: total number of reserved PEBs: 130
UBI: number of PEBs reserved for bad PEB handling: 2
UBI: max/mean erase counter: 809/648
UBI: image sequence number: 0
UBI: background thread “ubi_bgt0d” started, PID 936
UBIFS DBG (pid 941): ubifs_bg_thread: background thread “ubifs_bgt0_0” started, PID 941
UBIFS: mounted UBI device 0, volume 0, name “config”
UBIFS: file system size: 14602240 bytes (14260 KiB, 13 MiB, 115 LEBs)
UBIFS: journal size: 1015809 bytes (992 KiB, 0 MiB, 6 LEBs)
UBIFS: media format: w4/r0 (latest is w4/r0)
UBIFS: default compressor: lzo
UBIFS: reserved for root: 689699 bytes (673 KiB)
UBIFS DBG (pid 939): mount_ubifs: compiled on: Nov 16 2018 at 11:47:58
UBIFS DBG (pid 939): mount_ubifs: min. I/O unit size: 2048 bytes
UBIFS DBG (pid 939): mount_ubifs: max. write size: 2048 bytes
UBIFS DBG (pid 939): mount_ubifs: LEB size: 126976 bytes (124 KiB)
UBIFS DBG (pid 939): mount_ubifs: data journal heads: 1
UBIFS DBG (pid 939): mount_ubifs: UUID: 97B17EFB-A764-4C9B-A6CE-7BF03C3FE9D5
UBIFS DBG (pid 939): mount_ubifs: big_lpt 0
UBIFS DBG (pid 939): mount_ubifs: log LEBs: 3 (3 - 5)
UBIFS DBG (pid 939): mount_ubifs: LPT area LEBs: 2 (6 - 7)
UBIFS DBG (pid 939): mount_ubifs: orphan area LEBs: 1 (8 - 8)
UBIFS DBG (pid 939): mount_ubifs: main area LEBs: 115 (9 - 123)
UBIFS DBG (pid 939): mount_ubifs: index LEBs: 21
UBIFS DBG (pid 939): mount_ubifs: total index bytes: 16464 (16 KiB, 0 MiB)
UBIFS DBG (pid 939): mount_ubifs: key hash type: 0
UBIFS DBG (pid 939): mount_ubifs: tree fanout: 8
UBIFS DBG (pid 939): mount_ubifs: reserved GC LEB: 72
UBIFS DBG (pid 939): mount_ubifs: first main LEB: 9
UBIFS DBG (pid 939): mount_ubifs: max. znode size 240
UBIFS DBG (pid 939): mount_ubifs: max. index node size 192
UBIFS DBG (pid 939): mount_ubifs: node sizes: data 48, inode 160, dentry 56
UBIFS DBG (pid 939): mount_ubifs: node sizes: trun 56, sb 4096, master 512
UBIFS DBG (pid 939): mount_ubifs: node sizes: ref 64, cmt. start 32, orph 32
UBIFS DBG (pid 939): mount_ubifs: max. node sizes: data 4144, inode 4256 dentry 312, idx 188
UBIFS DBG (pid 939): mount_ubifs: dead watermark: 2048
UBIFS DBG (pid 939): mount_ubifs: dark watermark: 6144
UBIFS DBG (pid 939): mount_ubifs: LEB overhead: 2656
UBIFS DBG (pid 939): mount_ubifs: max. dark space: 706560 (690 KiB, 0 MiB)
UBIFS DBG (pid 939): mount_ubifs: maximum bud bytes: 634881 (620 KiB, 0 MiB)
UBIFS DBG (pid 939): mount_ubifs: BG commit bud bytes: 507905 (496 KiB, 0 MiB)
UBIFS DBG (pid 939): mount_ubifs: current bud bytes 45056 (44 KiB, 0 MiB)
UBIFS DBG (pid 939): mount_ubifs: max. seq. number: 16094623
UBIFS DBG (pid 939): mount_ubifs: commit number: 29874
jnl: driver (lke_9.0.0 lke_9.0.0_r239626_b48, LBD=ON) loaded at bf000000
ufsd: module license ‘Commercial product’ taints kernel.
Disabling lock debugging due to kernel taint
ufsd:: trace mask set to 0000000f
ufsd: driver (lke_9.0.0 lke_9.0.0_r239626_b48, LBD=ON, acl, ioctl, bdi, sd2(0), fua, bz, tr) loaded at bf028000
NTFS support included
Hfs+/HfsJ support included
optimized: speed
Build_for__WD_Lightning_4A_k3.2.40_32k_hybrid_2014-07-28_lke_9.0.0_r239626_b48
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
GbE port 0: TxEnable WA - Enabled, deep=1, tx_en_bk=1
Unknown ETH command
UBI: attaching mtd6 to ubi1
UBI: max. sequence number: 62
UBI: attached mtd6 to ubi1
UBI: MTD device name: “reserve”
UBI: MTD device size: 5 MiB
UBI: number of good PEBs: 40
UBI: available PEBs: 0
UBI: total number of reserved PEBs: 40
UBI: max/mean erase counter: 3/2
UBI: background thread “ubi_bgt1d” started, PID 3056
UBIFS DBG (pid 3073): ubifs_bg_thread: background thread “ubifs_bgt1_0” started, PID 3073
UBIFS: mounted UBI device 1, volume 0, name “reserve”
UBIFS: file system size: 3174400 bytes (3100 KiB, 3 MiB, 25 LEBs)
UBIFS: reserved for root: 149934 bytes (146 KiB)
UBIFS DBG (pid 3071): mount_ubifs: compiled on: Nov 16 2018 at 11:47:58
UBIFS DBG (pid 3071): mount_ubifs: min. I/O unit size: 2048 bytes
UBIFS DBG (pid 3071): mount_ubifs: max. write size: 2048 bytes
UBIFS DBG (pid 3071): mount_ubifs: LEB size: 126976 bytes (124 KiB)
UBIFS DBG (pid 3071): mount_ubifs: data journal heads: 1
UBIFS DBG (pid 3071): mount_ubifs: UUID: 80F0894D-B646-4810-AC7B-F29597A557F9
UBIFS DBG (pid 3071): mount_ubifs: big_lpt 0
UBIFS DBG (pid 3071): mount_ubifs: log LEBs: 3 (3 - 5)
UBIFS DBG (pid 3071): mount_ubifs: LPT area LEBs: 2 (6 - 7)
UBIFS DBG (pid 3071): mount_ubifs: orphan area LEBs: 1 (8 - 8)
UBIFS DBG (pid 3071): mount_ubifs: main area LEBs: 25 (9 - 33)
UBIFS DBG (pid 3071): mount_ubifs: index LEBs: 1
UBIFS DBG (pid 3071): mount_ubifs: total index bytes: 112 (0 KiB, 0 MiB)
UBIFS DBG (pid 3071): mount_ubifs: key hash type: 0
UBIFS DBG (pid 3071): mount_ubifs: tree fanout: 8
UBIFS DBG (pid 3071): mount_ubifs: reserved GC LEB: 11
UBIFS DBG (pid 3071): mount_ubifs: first main LEB: 9
UBIFS DBG (pid 3071): mount_ubifs: max. znode size 240
UBIFS DBG (pid 3071): mount_ubifs: max. index node size 192
UBIFS DBG (pid 3071): mount_ubifs: node sizes: data 48, inode 160, dentry 56
UBIFS DBG (pid 3071): mount_ubifs: node sizes: trun 56, sb 4096, master 512
UBIFS DBG (pid 3071): mount_ubifs: node sizes: ref 64, cmt. start 32, orph 32
UBIFS DBG (pid 3071): mount_ubifs: max. node sizes: data 4144, inode 4256 dentry 312, idx 188
UBIFS DBG (pid 3071): mount_ubifs: dead watermark: 2048
UBIFS DBG (pid 3071): mount_ubifs: dark watermark: 6144
UBIFS DBG (pid 3071): mount_ubifs: LEB overhead: 2656
UBIFS DBG (pid 3071): mount_ubifs: max. dark space: 153600 (150 KiB, 0 MiB)
UBIFS DBG (pid 3071): mount_ubifs: maximum bud bytes: 634881 (620 KiB, 0 MiB)
UBIFS DBG (pid 3071): mount_ubifs: BG commit bud bytes: 507905 (496 KiB, 0 MiB)
UBIFS DBG (pid 3071): mount_ubifs: current bud bytes 247808 (242 KiB, 0 MiB)
UBIFS DBG (pid 3071): mount_ubifs: max. seq. number: 378
UBIFS DBG (pid 3071): mount_ubifs: commit number: 46
UBIFS: un-mount UBI device 1, volume 0
UBIFS DBG (pid 3073): ubifs_bg_thread: background thread “ubifs_bgt1_0” stops
egiga0: mac address changed
egiga1: mac address changed
egiga0: link down
egiga0: started
egiga1: started
NET: Registered protocol family 10
ADDRCONF(NETDEV_UP): egiga0: link is not ready
ADDRCONF(NETDEV_UP): egiga1: link is not ready
IPv6 over IPv4 tunneling driver
bonding: Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
bonding: MII link monitoring set to 500 ms
egiga0: link up, full duplex, speed 1 Gbps
ADDRCONF(NETDEV_CHANGE): egiga0: link becomes ready
8021q: adding VLAN 0 to HW filter on device bond0
ADDRCONF(NETDEV_UP): bond0: link is not ready
egiga0: stopped
egiga0: link down
egiga0: started
bonding: bond0: enslaving egiga0 as a backup interface with a down link.
egiga1: stopped
egiga1: started
bonding: bond0: enslaving egiga1 as a backup interface with a down link.
restart sysinfod…
bonding: bond0: link status up for interface egiga0, enabling it in 0 ms.
bonding: bond0: link status definitely up for interface egiga0, 1000 Mbps full duplex.
bonding: bond0: making interface egiga0 the new active one.
bonding: bond0: first active interface up!
ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
md: bind
md: bind
md: bind
bio: create slab at 1
md/raid1:md0: active with 3 out of 3 mirrors
md0: bitmap file is out of date (0 < 1) – forcing full recovery
created bitmap (16 pages) for device md0
md0: bitmap file is out of date, doing full recovery
md0: bitmap initialized from disk: read 2/2 pages, set 262136 of 262136 bits
md0: detected capacity change from 0 to 2147418112
md0: unknown partition table
Adding 2097056k swap on /dev/md0. Priority:-1 extents:1 across:2097056k
EXT4-fs (sda4): mounted filesystem with ordered data mode. Stripe: 128 Opts: usrquota,grpquota
EXT4-fs (sdb4): mounted filesystem with ordered data mode. Stripe: 128 Opts: usrquota,grpquota
EXT4-fs (sdc4): mounted filesystem with ordered data mode. Stripe: 128 Opts: usrquota,grpquota
md: md1 stopped.
md: bind
md: bind
md: bind
md/raid:md1: device sda2 operational as raid disk 0
md/raid:md1: device sdc2 operational as raid disk 3
md/raid:md1: device sdb2 operational as raid disk 1
md/raid:md1: allocated 32890kB
md/raid:md1: raid level 5 active with 3 out of 4 devices, algorithm 2
RAID conf printout:
— level:5 rd:4 wd:3
disk 0, o:1, dev:sda2
disk 1, o:1, dev:sdb2
disk 3, o:1, dev:sdc2
created bitmap (1 pages) for device md1
md1: bitmap initialized from disk: read 1/1 pages, set 26 of 14889 bits
md1: detected capacity change from 0 to 11989469822976
md1: unknown partition table
EXT4-fs (md1): mounted filesystem with ordered data mode. Stripe: 48 Opts: usrquota,grpquota
nf_conntrack version 0.5.0 (8052 buckets, 32208 max)
ip_tables: (C) 2000-2006 Netfilter Core Team
ip6_tables: (C) 2000-2006 Netfilter Core Team
netlink: 12 bytes leftover after parsing attributes.
Loading iSCSI transport class v2.0-870.
iscsi: registered transport (tcp)
ata4: exception Emask 0x10 SAct 0x0 SErr 0x180000 action 0x6 frozen
ata4: edma_err_cause=00000020 pp_flags=00000000, SError=00180000
ata4: SError: { 10B8B Dispar }
ata4: hard resetting link
ata4: EH complete
ata3: exception Emask 0x10 SAct 0x0 SErr 0x4010000 action 0xe frozen
ata3: edma_err_cause=00000010 pp_flags=00000000, dev connect
ata3: SError: { PHYRdyChg DevExch }
ata3: hard resetting link
ata3: link is slow to respond, please be patient (ready=0)
ata3: SRST failed (errno=-16)
ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata3.00: ATA-9: WDC WD40PURX-64GVNY0, 80.00A80, max UDMA/133
ata3.00: 7814037168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata3.00: configured for UDMA/133
ata3: EH complete
scsi 2:0:0:0: Direct-Access ATA WDC WD40PURX-64G 80.0 PQ: 0 ANSI: 5
sd 2:0:0:0: [sdd] 7814037168 512-byte logical blocks: (4.00 TB/3.63 TiB)
sd 2:0:0:0: [sdd] 4096-byte physical blocks
sd 2:0:0:0: Attached scsi generic sg3 type 0
sd 2:0:0:0: [sdd] Write Protect is off
sd 2:0:0:0: [sdd] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
Alternate GPT is invalid, using primary GPT.
sdd: sdd1 sdd2 sdd3 sdd4
sd 2:0:0:0: [sdd] Attached SCSI disk
hotPlug.sh begin(seq=758)…
hotPlug.sh end(seq=758).
md: bind
RAID1 conf printout:
— wd:3 rd:4
disk 0, wo:0, o:1, dev:sda1
disk 1, wo:0, o:1, dev:sdb1
disk 2, wo:0, o:1, dev:sdc1
disk 3, wo:1, o:1, dev:sdd1
md: recovery of RAID array md0
md: minimum guaranteed speed: 200000 KB/sec/disk.
md: using maximum available idle IO bandwidth (but not more than 1000 KB/sec) for recovery.
md: using 1024k window, over a total of 2097088k.
md: md0: recovery done.
— wd:3 rd:4
— wd:3 rd:4
md: resuming recovery of md0 from checkpoint.
FAT-fs (sdd4): Unrecognized mount option “usrquota” or missing value
ufsd: failed to mount “sdd4”. bad option “usrquota”
— wd:4 rd:4
disk 3, wo:0, o:1, dev:sdd1
md/raid1:md0: Disk failure on sdd1, disabling device.
md/raid1:md0: Operation continuing on 3 devices.
— wd:3 rd:4
disk 3, wo:1, o:0, dev:sdd1
— wd:3 rd:4
md: unbind
md: export_rdev(sdd1)
sd 2:0:0:0: [sdd] Synchronizing SCSI cache
sd 2:0:0:0: [sdd] Stopping disk
ata3.00: disabled
hotPlug.sh begin(seq=772)…
ata3: exception Emask 0x10 SAct 0x0 SErr 0x180000 action 0x6 frozen
ata3: edma_err_cause=00000020 pp_flags=00000000, SError=00180000
ata3: SError: { 10B8B Dispar }
ata3: EH complete
hotPlug.sh end(seq=772).
ata3: EH complete
hotPlug.sh begin(seq=782)…
hotPlug.sh end(seq=782).
md: bind
— wd:3 rd:4
— wd:4 rd:4
EXT4-fs (md1): re-mounted. Opts: usrquota,grpquota,init_itable=10
— wd:3 rd:4
— wd:3 rd:4
md: unbind
ata3.00: disabled
hotPlug.sh begin(seq=796)…
ata3: EH complete
hotPlug.sh end(seq=796).
ata3: EH complete
hotPlug.sh begin(seq=806)…
hotPlug.sh end(seq=806).
md: bind
— wd:3 rd:4
— wd:4 rd:4
ata3.00: disabled
hotPlug.sh begin(seq=819)…
md: super_written gets error=-19, uptodate=0
— wd:3 rd:4
— wd:3 rd:4
md: unbind
ata3: EH complete
hotPlug.sh end(seq=819).
ata3: EH complete
hotPlug.sh begin(seq=830)…
hotPlug.sh end(seq=830).
md: bind
— wd:3 rd:4
— wd:4 rd:4
md: bind
RAID conf printout:
— level:5 rd:4 wd:3
disk 2, o:1, dev:sdd2
md: recovery of RAID array md1
md: minimum guaranteed speed: 1000 KB/sec/disk.
md: using maximum available idle IO bandwidth (but not more than 200000 KB/sec) for recovery.
md: using 1024k window, over a total of 3902822208k.
