Hey!
Can someone please confirm if I were to but a 4TB EX2 Ultra (£269.99) which by factory default is set to RAID 1, does this come with 2x 4TB drives, or 2x 2TB drives?
Same question for the My Cloud Mirror 4TB (£282.00) which as I understand can only be configured in RAID 1…
This may go somewhere to explain why the price for the Mirror is more…
Many thanks
Thanks for the reply. Simple maths indeed, however the reason for the confusion is that a 4TB Cloud Mirror drive (which can only be used in RAID 1 I believe) is therefore only 2TB of usable storage according to the “simple maths” rule. Slightly misleading from WD I would suggest…
Its upto users who can use it to full capcity. WD nor any manfactures restrict the usage.
If you need reduncy then have it RAID 1. or else if you need full storage then set up as JBOD.
Still you can replicate the data to another drive until the usage is not exceeding 2tb.
As this way one can have backup and still use the 2nd drive until its full.
