Netgear WNDA3100 v2 will not work with WD Live TV Plus
This wireless network adapter will not work with live tv plus.
There is no driver for it On the WD Live device, not supported.
This adapter has to have a netgear
driver installed Before it will even work on a PC.
If trying to use it on the WD Live Tv Plus media streamer
the adapter blue light will come on solid but it is never
recognized. There will be no ‘wireless’ option in the network
setup.
It will not work, according to WD Support. I tried and it doesn’t.
Have you seen the WD list of approved adapters?
Approved Adapters
If you look at the list, you will see that the WNDA3100 adapter revision number in the chart is: ‘Not Listed’. That means no revision (revision 0). If V2 was supported, the chart would say V2. The WNDA3100 V2 is not supported. You need to pick an adapter that is on the list.
Hi - first info about WNDA3100 V2 are from feb.2010 (!)
“Re: Just tested Netgear USB device (wnda3100). WD TV Live Plus does not detect it.   09-02-2010 04:54 PM”
It is were good Wifi USB adapter and work fast / long distance with dual band router from Netgear
Why does it take 1 year to put this driver on WD TV (?)
Please make it sap :slight_smile:
reagards Happy WDTV user
