It has some kind of goofy 5-pin DC in plug that looks like an S-Video plug. I kinda need to get the data off this drive, but I can’t until I find this cable. Any ideas?
WD1200B005-RNN
WD1200B005-RNN
See if you can find it here https://wdc.custhelp.com/app/answers/detail/a_id/1378/session/L3RpbWUvMTMyMDE3MTc3OS9zaWQvak9TMVcxSWs%3D
Joe
WD1200B005-RNN
This appears to be the model you have:
Specifications for the WD USB Series I 120 GB Hard Drive WD1200B005
Performance Specifications Physical Specifications Physical Dimensions Environmental Specifications Power Requirements Technical Documents |
The drive is part of our Legacy products but you should be able to find a compatible adapter in your local computer shop which the specs provided on the link.
