its been 2 days of trial and error reformatting my wd element 2tb still nothing im using win 10 used cmd, disk management, wd quick formatter and even the common way to format using the right click format and one time it showed an error saying that it was unsuccessful to format can someone help me?
have you tried deleting the Partition 1st and then Creating a Partition / Formatting ?
eg. or using AOMEI Partition Assistant Standard 6.0 … [Freeware Version]
right click on the drive … “Delete Partition” then “Apply” then …
right click on the drive … “Create Partition” select your Format eg. NTFS etc then “Apply”
ok ill try this one and hope it works
when i was trying to delete partition this showed up i read the code 6 but i dont understand
does it take too long for a 2TB to format?
