Hi , i have My Passport Essential SE 1TB bought in Apr. It was working fine since yesterday when i put it into my friends laptop ( winxp) , now it asks " you need to format this drive f:/ before you can continue".
( i have win Vista on my laptop) -
i tried to remove and plugged again ( all USB ports) - no use.
-i tried to run chkdsk , but it shows hd partition as RAW , in Disk Management it shows 32gb as drive F: and rest 899GB as unallocated.
-i also tried to change the drive letter for F: - didnt work
-Running WD Diagnostics showed PASS in quick test.
Can anyone please suggest a way i can try to make it running again w/o loosing the data ?
Thanks in advance
