My Cloud EX2 rebuild raid 1 problem
After one of my raid 1 disk was turn into degraded and a red lamp on device, i replace the faulty disk with the same new one but the lamp is still red and i can’t see the auto-rebuild section. The disk status is both good. Any advice?
Hi @LoisWan,
Please refer below link to replacing an internal drive on a multi-bay My Cloud:
Hope it helps!!
I have already did that @Keerti_01.
Hello @LoisWan,
The RAID Rebuild process can be slower when there are other My Cloud processes and services consuming memory and CPU resources.
Please refer below link to rebuild the My Cloud drive:My Cloud: Slower Than Expected RAID Rebuild
Please refer link for more technical Inquiry : Support Login
